What battery charger do you use?
/ What battery charger do you use? #51
I have schumachers, they charge just fine. I also have a couple noco's and an optima. These are all more tenders though, 2-4a output, they're a bit smart and cut off.
My charger on wheels is an old sears, 2a, 15a, 50a, 125a. It's pretty reliable.
/ What battery charger do you use? #52
I added a couple small diodes in the leads to prevent the charging circuit for cause feedback issues. May not be needed, but i had them laying around.
/ What battery charger do you use? #53
I suddenly feel the need to point out that I’ve already weighed in on this topic. (+ 4)
/ What battery charger do you use? #54
Thinking about getting this one.
/ What battery charger do you use? #55
I use Battery Minders for the atv. I have a schumacher for the tractors, works good for my needs.
/ What battery charger do you use? #56
I use the HF model Topzide recommended. I have 5 of them. All are over 5 years old now.
/ What battery charger do you use? #57
I have an AGM battery in my Hustler Raptor X lawn mower that needs charging. I've been told that a normal battery charger (Schumacher SC-600A) can't be used. What battery charger are you using for AGM batteries? Also, the battery in my Kioti DK4510 is getting weak, and I'm thinking of replacing it with an AGM battery. Any suggestions and/or issues?
I bought an "automatic" one from the auto parts store because I all too often left the 2 amp fixed charger on way to long.
Both seem to work, Batteries are my most laborsome maintainance task. Way too many!
/ What battery charger do you use? #58
I have an older roll around Schumacher that does 6v, 12v 10A, 40A and 200A starting.
I guess one day I'll need go get an AGM compatible charger, but honestly for my applications the AGM isn't worth the extra money.
Sent from my SM-S921U using TractorByNet mobile app
2014 International DuraStar 4400 Service Truck with Crane, VIN # 3HAMKAAN0EL771639 (A61165)
2014 International...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
Kubota B2301 (A53317)
Marliss 15' Grain Drill (A60462)
Marliss 15' Grain...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
