What battery charger do you use?
   / What battery charger do you use? #71
Thinking about getting this one.
Hey Airbiscuit how’s that 100 amp jump start working for ya? I find it difficult to believe since that thing is so small. But a hundred amps ain’t much compared to a 600 amp cca battery
   / What battery charger do you use? #72
I have an AGM battery in my Hustler Raptor X lawn mower that needs charging. I've been told that a normal battery charger (Schumacher SC-600A) can't be used. What battery charger are you using for AGM batteries? Also, the battery in my Kioti DK4510 is getting weak, and I'm thinking of replacing it with an AGM battery. Any suggestions and/or issues?
NOCO from Walmart or Amazon. Super solid and reliable.
   / What battery charger do you use? #73
I have had two BatteryMinders fail, one that flatted a battery out.
Bummer. I probably have at least 10 BatteryMINDers by now, the oldest ones from the late '90s. Never an issue...so far.
Recently had a small NOCO kill a good battery, though.
   / What battery charger do you use? #74
What you have to understand is a battery is a chemical reaction, it will attempt to justify load (amperage output) no matter what it is till it implodes....
   / What battery charger do you use? #75
I have one of the CTEK chargers, which has the correct charging profile for AGM batteries and conventional ones. It automatically transitions to a maintainer once a battery is charged. Supposedly, it also has the ability to work miracles with discharged/neglected batteries. Overall, it seems to work well, so I'm happy.
For faster charging of a discharged battery, I'll hook up my several decades old Schumacher charger that keeps on tickin'.
   / What battery charger do you use? #78
I don't have near 10, but I do have three BatteryMinders and haven't had any issues yet either!
   / What battery charger do you use? #79
NOCO Genius10 Multi-stage charging, desulfator, lithium/AGM/flooded modes, waterproof, auto float mode for maintenance
   / What battery charger do you use? #80
Each of my 5 trailers has a battery, the only one with a solar charger is the fuel trailer. Some sit for an extended time without being used and are not near a plug for a charger. I just bought the Dewalt 4-amp charger/power pack that uses the 20V Dewalt batteries. Plan is to put it on a trailer and let it charge up. The charger indicates when it is a full charge. It is not a jump starter, just a trickle charger. No more dragging the big charger around or stretching extension cords.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
TANK MANIFOLD (A58214)
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
