trail clearing technique and tools
/ trail clearing technique and tools #1,261
My wife recently got a rock thrown at her, nailed her just below the knee - big bruise.
Heavy pants on, but not her leather motorcycle chaps that she's often used in the past.
We wear those hiking boots that go above your ankle and double fronted pants with foam knee pads in them. All that is not 100% but it sure helps.
/ trail clearing technique and tools #1,263
A few years ago I shattered the left rear side window out of our 93 suburban with a weed-eater and rock. Yikes! 🙃
I'm back clearing weeds n shoots at my ol bosses property's but I've taken no photos to post. Seems he can't get anyone to do it and I like this work. I was going through a string every 120 seconds so I switched to wet ones which did seem to help. I'll post more about this later.
/ trail clearing technique and tools #1,268
The U.S.Forestry Service seems to think thier $15-$17/hr pay is enough. That's not competitive with private companies with $25/hr strarting pay. There's a lot more to that trade other than handling a shovel.
Granted, one must have a calling to want to do the heavy lifting part of that job, but some find reward in the results adequate. We all appreciate the results. Besides, who would take pride in their work just flipping burgers as a career?
/ trail clearing technique and tools #1,270
Best thing I have since 2018 is a 5' tarter tsc, bushhog for maintaining overgrown xmas tree rows. Decimates new "shoots" of popple, birch, and aspen, carelessly bent the deck a little, went thru my faire share of shear bolts, and an overrun coupler but still going strong, checking gearbox fluid , frequently greasing u-joints etc, if I had more time or something I'd probably try and build a off set to one side to mount it on tph. Found a hydraulic top link aids significantly for setting the deck and cut height.
/ trail clearing technique and tools #1,271
I am reusing the Ash trees here, benches, tables, firewood.
Cord after cord after cord. Still have a few dozen out in the woods that haven't fallen yet.
I am using the tractor and forks or BH with thumb to move the fallen trunks and branches to piles.
I have lots to go still. Some trails still restricted as trees along them still dropping branches.
Stopped at implement dealer yesterday and noted this forestry cutting head. It seems that the cutters rotation was reversible.
/ trail clearing technique and tools #1,273
Picked up a 5’ Brown tree cutter for $1200. Needed some TLC. Most of the wear was from sitting outside. Great for trails. Chips better than a rotary cutter. Can cut stems off easier than rotary cutter. Still shreds weeds or even 7’ high kudzu. At the low side of required HP @45. HST almost a must.
Incredibly expensive new but can find used in the southeast. Now that I have first hand experience using a valuable tool for tree thick farm is well worth the investment. Evasive woody plants are usually the worst for trails and perimeter encroachment.
We hiked a local trail yesterday and found it like this. Parking lot was a mess, sign was barley visible from the road etc, etc. 5 styles of blazes seen and many installed flat side to the path, around 10 dead-falls across it. We stopped several times to locate the tread. Oh well.
/ trail clearing technique and tools #1,276
Here is how to not install a blaze. Dearest is on the trail.
Have you run into any prohibition or restriction using gasoline powered equipment to perform trail maintainence?
Here it is banned but government agencies freely ignore the prohibition but small time mom and pop are on the hook to be electric otherwise subject to fines.
No
/ trail clearing technique and tools #1,279
It's about time!
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
John Deere MX8 3-Pt 8' Rotary Mower (A66285)
John Deere MX8...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
John Deere 825 6R Cultivator (A66408)
John Deere 825 6R...
TEREX SS1056C (INOPERABLE) (A65643)
TEREX SS1056C...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
