Traction Technique?
/ Traction Technique? #31
I have a set of V-Bar chains for my truck. Like driving over a Cordroy road (sp?). I would say if you are on a dirt road or an area where the snow does not melt for several months go with V-Bar. Otherwise normal chains work fine. A half mile concrete driveway gotta cost $1,500,000. + labour. If I had that kind of money I'd buy a skid steer on rubber tracks to do the driveway.
/ Traction Technique? #32
Not quite that much... but it is a lot. I will do the work myself to save as much as I can.
The main reason I need the chains is to get through my snowy pasture to get round bales to the animals.
/ Traction Technique? #33
I have a set of v-bars that I rarely use and have not needed since I grooved the tires. I used to need them in any heavy wet snow. they did put little chips in my 4000 psi concrete floor and did noticably scratch up any driveway that I spun on (which was just about every driveway I plowed). They do help traction a lot on gravel but chains spin on asphalt fairly easily. There is one manufacturer who actually sells rubber "chains". You can probably find it on the web.
/ Traction Technique? #34
I have not heard of grooving tires. Can you explain how this is done... Maybe some pictures?
/ Traction Technique? #35
Will be using my tractor on dirt, gravel, so V-bar chains would be the way too go for me, will put down a couple sheets of plywood on the cement floor in the barn to avoid messing up the concrete.
BY
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2018 Sea Pro Boat with 2021 Magic Tilt 17ft S/A Boat Trailer (A59231)
2018 Sea Pro Boat...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
(INOP) 1996 FORD F150 SINGLE CAB TRUCK (A59823)
(INOP) 1996 FORD...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
