2017 6120M steering issue
/ 2017 6120M steering issue #1
Dadnatron
Veteran Member
Versailles, KY
JD 5100e with FEL
2017 6120M 1700hrs
Purchased this used from dealer last fall. Haven’t really done much with it until today, planting grass seed.
There is NO steering lock/end side to side. When I turn either direction… it goes and goes. The tires hit their end, but the steering wheel continues to turn. The tires then fade back unless you continue turning. This becomes an issue as the tractor won’t hold side hills without constantly turning the wheel. And I don’t mean just holding pressure against the hillside… I mean spinning the wheel. On a small side hill, I was turning it 1 completely revolution about every 10yds. The tractor continued to drift down the hill, which is normal, but the steering wouldn’t hold it.
It’s the oddest thing and I don’t know if it’s something ‘new’ in this model or what in the heck it could be otherwise. It is difficult to back up as well, because you can’t just crank it to a lock and reverse… you have to continually turn the wheel around and around.
Thoughts? I’ve owned a similar year 5100E which worked normally. I grew up on a 4020 and couple IH. They both locked when turning. This tractor is awful to drive because it’s a constant struggle to maintain a line of any sort.
Another thing I noticed today was the FEL leaks down as well, while driving. Haven’t noticed this before, but I’ve been using it primarily, not leaving it static and farming. With or without the bucket, it drops significantly, ending up at the groundif I don’t adjust. Don’t know if they could have the same underlying issue with hydraulics.
/ 2017 6120M steering issue #2
I don't know the mechanism for the steering, but perhaps there is a relief valve or a check value that isn't holding pressure?
Anyone know a forum which might have more information or have people who might have more information? My local dealer does decent work, but they charge me anytime I see a deer, much less ask them a question.
/ 2017 6120M steering issue #5
I agree with Harry check steering cylinder for failed piston seal.
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2008 CATERPILLAR 242B2 SKID STEER (A65053)
2008 CATERPILLAR...
BUSH HOG 4R48" ROLLING CULTIVATOR (A64278)
BUSH HOG 4R48"...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
