Dirt Moving Tooth Bar Advice
/ Tooth Bar Advice
Looks like new. Only question left is whether a 6' box blade like this is too wide for my B2410 with 24 HP? Driveway is a sandy loam that has been packed tight from years of driving over it.
/ Tooth Bar Advice #33
It is, I thought about that afterwards... Do you have AG tires, that would help. It also only has 3 teeth. Not sure how hard it would be to cut a couple more sockets into it.
I would be tempted to buy and list it for trade for a smaller one ???
/ Tooth Bar Advice
Tires are R4. With only 3 teeth, it might pull it, but that means more passes. Weighs 450 pounds.
Any more thoughts or comments?
/ Tooth Bar Advice #35
Agri-Supply in Gardner would have more teeth, if you're able to add them... You could just use two teeth, pull the extra one out. With the soil type you have down there, you might be able to use it with caution. Worst case it stops the tractor, pick it up a little and carry on. Does your tractor have 4 wheel drive? If it's 2 wheel drive, forget about it and keep looking.
UPDATE: Your tractor is only 1500 lbs... you'll most likely will just be spinning your wheels - do you have a FEL? that will help a little... Like I said maybe buy it and trade for a smaller one.
/ Tooth Bar Advice
It's 4 wheel drive. I may bite on it and see what happens. Worst case scenario, it will not be what I need. Sell it and try something else...
Update: Yes, it has a front end loader.
/ Tooth Bar Advice #37
NC419N, please excuse my lack of knowledge. Can you please explain what you mean by "a BX Expander bolt in front bucket blade"? Thanks!
BXpanded Piranha Tooth Bar
The Piranha is custom built to fit your loader bucket based on actual inside bucket width. Please select your actual inside bucket width above or email us at contact@bxpanded.com for more information. For measuring instructions click here.
/ Tooth Bar Advice #38
/ Tooth Bar Advice
Well, I have one ordered! Hopefully it will be just what I need....
Thanks to all who commented.
/ Tooth Bar Advice #40
Came in yesterday and got it installed. The bar went right on and fit perfect. No grinding no cutting.
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A59230)
2013 Chevrolet...
New Holland T2420 (A53317)
New Holland T2420...
2018 Nissan Rogue SUV (A59231)
2018 Nissan Rogue...
2017 Hino 268 Cab and Chassis Truck (A59230)
2017 Hino 268 Cab...
