Tooth bar vs none difference?
/ Tooth bar vs none difference? #1
fatjay
Elite Member
Eastern PA
Not enough
I'm having a hell of a time using my kubota's bucket to scoop dirt, as the pile has been sitting for a few years and it's become compacted and weeds are growing. I thought about adding a tooth bar to it to try and break it up more easily. In this specific case, will a tooth bar make much difference? It's a 48" bucket pushed by my b7200 so it's not a big tractor, and i have turf tires so even with 4wd, I'm not getting crazy traction. Even so, sometimes the HST can't overcome the traction on the ground when trying to dig into the dirt mound.
Will a tooth bar make much difference, or would I be wasting my money?
/ Tooth bar vs none difference? #3
I do not have a tooth bar on my bucket, but I often wish I did. Need to buy a Pirannah tooth bar soon.
/ Tooth bar vs none difference? #4
The old style bar with long teeth work really well for hard soil. The piranha style is better for cutting and ripping roots and vegetation.
Ok i bought a tooth bar. Should be here by friday.
What's the worst that can happen?
/ Tooth bar vs none difference? #8
While you wait for the ripper bar try chaining your technique. Enter the pile at mid height from an angle with a little more speed and see if You cant get a little bite. Dump that and try again from a different angle always using the corner of the bucket. Once you have dumped a few half or 1/3rd buckets in front of the pile go ahead and load and move a full bucket
I'm not familiar with vevor, but they had a lot of reviews and they were mostly positive. And it's hard to find something not built with child/slave labor these days, including clothing, computers, phones, or even food. Not that i condone such practices.
My technique is hit it with some speed mid height with the bucket tilted a hair down, then curl and lift at the same time, and that usually gives me half a bucket. But I have to hit it with speed, and sometimes it takes 2-3 hits. I'd like to scoop more easily and be less hard on the machine.
/ Tooth bar vs none difference? #10
Try the corner of the bucket vs hitting it full or square on.
/ Tooth bar vs none difference? #11
If you have a box blade you might be able to knock it down with that.
/ Tooth bar vs none difference? #12
Try peeling a thin layer off the pile while gently pushing into the pile and raising loader vs ramming into it
The funny thing is I have 2 tractors that would make quick work of it, but they're on the other side of the dirt pile and I can't get them out until I make headway with the pile. There's even a ton of concrete in a big chunk that I put on top of the dirt pile that I can't get off without the tractor that put it there.
I have been hitting it with the edges and getting more progress. but it's slow. Lots of rocks as well, if i hit the big rocks with the blade it stops it dead, then i have to either go under or over the rock.
/ Tooth bar vs none difference? #15
Tooth bars help a lot digging compacted soil IMO, but they will still stop dead on big rocks
/ Tooth bar vs none difference? #16
In my experience, (Tooth bar vs none) :: (Dirt vs none).
Definitely a good idea to get one.
I've got a piranha tooth bar; it works great for dirt that's reasonably compacted but not actually hard. I think the teeth you got are going to be fantastic as it'll probably be able to dig into even harder stuff, possibly even point the teeth mostly down, push down on the bucket, then roll the bucket back and you'll get a nice chunk of hard dirt out (don't drive forward with the teeth straight down though!).
A nice thing about the PTB I've found is that you can push it into a smaller tree and uproot them, and also I've found it super useful in pulling brambles and jungles of small shrubs without completely destroying the soil by similarly catching stems with the ptb and shoving; the sharpness of the bar is such that you can shave hard stuff, but there's still a lot of bar hitting hard so if the dirt is really hard it won't sink in like the teeth will.
Can't advise ramming the bucket in at all. I understand the sentiment but that shock isn't going to be good in the long run. Front end loaders on little tractors are not built to push hard, they're not excavators or dozers and the design case is for loose material. YMMV and it's your tractor but don't be surprised if you crack or bend something by ramming.
Going for the corner of the bucket - slow and occasionally yes, and make sure you trade off which corner often; note that you're deliberately setting up uneven forces on the loader and something's going to tweak in the long term.
/ Tooth bar vs none difference? #17
Tooth bars are absolutely worth the investment. Huge difference when digging into hard, compacted soil or breaking up a pile of material (dirt, gravel) that has settled and compacted.
I made one because I had the steel on hand and I'm often too cheap for my own good, but the Piranha bar is worth the money if you don't want to make one.
The complicated part is, i can't dig under hte rock either, with a strait blade on the bucket. So I have to get out and go dig the rock out by hand to make any progress.
/ Tooth bar vs none difference? #19
Bought a tooth bar and leave it on all the time. It's a beast, game changer, too bad it was made by EA, no longer available I hear...
/ Tooth bar vs none difference? #20
Yeah I've never taken mine off either.
Causes a problem when I go put a clamp-on trailer hitch on the bucket but I manage.
I've actually found that since I got the ptb, I've never put the ratchet rake onto the bucket because the ptb has a similar effect (though since it's back-dragging one must take more care); I should probably sell that.
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
