Tooth bar?
/ Tooth bar? #31
Post #27 shows my bucket and tooth bar. I've used it to dig - gently. Not much any more. My situation - I have from "0" to ten plus feet" of soil over SOLID basaltic lava bedrock. If I'm not very careful - the tooth bar could get hooked on the bedrock - resulting in SOMETHING being damaged. It's just not worth it.
SO........ I gather up with the rear blade or use the scarifiers on the ROBB to dig - scoop up with the bucket. Nothing ever gets damaged.
Besides - the thought of even trying to dig out one of my ancient Ponderosa pines - ludicrous. They run 24" to 42" on the base.
Yes - I've sure found my M6040 to be a very worthy machine. After 15 years - everything still works as it did brand new.
/ Tooth bar? #32
a heavy duty tooth bar on a heavy duty utility tractor is a win situation. assuming the operator knows when to let up in a bind. extracted many a boulder from field & moved earth on dams thanks to the hd Woods bar... as far as back dragging, i just use the heel rather than blade, regards
/ Tooth bar? #33
When you said tooth bar I was thinking of the piranha tooth
bar is what I use for removing cactus. For stumps small ones
It has the cutting edges
willy
/ Tooth bar?
Just got my Piranha tooth bar. I'm going to attack that stump as soon as the frost melts, wish me luck.
/ Tooth bar? #36
Maybe a little late, but since you plan to build a shed over the site, had you considered just renting a stump grinder for a day?
/ Tooth bar? #37
I didn't read all 4 pages and I hate being a negative Nancy because there too many of them around TBN already but... You are going to have a heck of a time digging out 10" stumps that are 4 " high. I had a stump bucket (that I now sold because stump digging is hell on a FEL) and I had a hard enough time digging out trees that were 6" dia. and 4 feet high. Don't do it! Nothing but heartache in that life.
/ Tooth bar?
It's on a little bit of an incline so I prefer to remove it, if possible. Otherwise, the shed will be higher than I would like it to be.
/ Tooth bar?
It's an 8" maple, if I can't dig it out then I will cut it a low as possible and build over it. But I'm going to give it a go first. I will report back with my success, or failure!
I still have other uses for the tooth bar, so I won't regret the purchase.
/ Tooth bar? #40
It's an 8" maple, if I can't dig it out then I will cut it a low as possible and fill build over it. But I'm going to give it a go first. I will report back with my success, or failure!
I would love a Piranha toothbar, they look super handy. You will definitely use it!
All I can say is take your time with the stump digging. I broke my QA plate doing it, thankfully it was a bad weld and was covered under warranty.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
