Front-End Loader Tooth bar advice please
/ Tooth bar advice please
Thanks guys for your thoughts. Much appreciated. Decided that my requirements are really on the light duty side, rather short term, and the cost/benefit of a tooth bar hard to justify. At least for now. I'm new to this forum, but am learning a boat load of stuff from veterans like you...Ray
/ Tooth bar advice please #12
Here are a couple of options if you are considering one
Option 1 is the Long Tooth Bar. It is flat, with smooth backdragging capabilities, that should pick up the fine/finish material:
Tooth Bars TB, STB, and ITB
Option 2 is inexpensive, lightweight, easy to install/remove: Berlon: Mini Tooth Bar
Hmmm. Interesting options you pose here Don. Will look into them. Thanks a bunch.
Ray
/ Tooth bar advice please #14
In deference to others experience, I find that a tooth bar is helpful for back dragging: it allows me to fluff up the gravel and smooth the driveway up. Plus it makes it easy to not dig or scarf the ground as the ground varies.
But it doesn't sound like it will address your needs.
It does make digging much more effective.
And it will penetrate hard ground much better (bought mine last spring and dug a foundation for an addition to my house). A box scrapper with rippers would be a good tool to have as well.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2004 John Deere 4720 (A60462)
2004 John Deere...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
Giyi 32" Excavator Bucket (A60463)
Giyi 32" Excavator...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
