The last Barn. (maybe)
/ The last Barn. (maybe) #122
Great build amazing video thanks for sharing
/ The last Barn. (maybe) #123
Great video. Lots of helpers!
Am surprised no bracing on posts, especially lifting those massive roof sections.
I'll admit it was a little scary. While it made it easier doing much of the work on the ground I would not do it that way again.
/ The last Barn. (maybe) #127
Watching your video, I was really impressed by the size of your posts!!!! That was a lot of work.
/ The last Barn. (maybe) #130
Did you pour footers under the poles? Or use premade concrete ones? We’re the poles concreted in place to hold them without bracing?
I put some sacrete under each post then filled the holes with sacrete with a hose going. My boys added the concrete while I leveled the post while making sure it was up against the string line. Not very scientific but it works. :)
I finally got the lights done in the barn. Each light is 18,000 lumens with 14 in the main area. I still need some plugs and lights over the work bench and the electrical work will be done for the most part.
They are very bright and I'm happy with them.
/ The last Barn. (maybe) #133
LED high bays? Are they dimmable?
/ The last Barn. (maybe) #135
Amazing barn build, and beautiful property. I can't see more than 20' out of my doors except forest, which is pretty in its own way.
Where do you all shoot around there? I was envisioning a range behind your barn.
Take care and be in good health, thanks for sharing.
I have miles of National Forest just behind my house and I can shoot all I want. No need to load wheelers or side by side up just drive it right from the house.
/ The last Barn. (maybe) #139
whoa, nice video to help understand the building assembly process. You had a lot of good helpers!!
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2023 Case TV380 (A62177)
2023 Case TV380...
Cat V80C Forklift (A65579)
Cat V80C Forklift...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
LOOK! (A65640)
LOOK! (A65640)
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
