The last Barn. (maybe)
/ The last Barn. (maybe) #122
Great build amazing video thanks for sharing
/ The last Barn. (maybe) #123
Great video. Lots of helpers!
Am surprised no bracing on posts, especially lifting those massive roof sections.
I'll admit it was a little scary. While it made it easier doing much of the work on the ground I would not do it that way again.
/ The last Barn. (maybe) #127
Watching your video, I was really impressed by the size of your posts!!!! That was a lot of work.
/ The last Barn. (maybe) #130
Did you pour footers under the poles? Or use premade concrete ones? We’re the poles concreted in place to hold them without bracing?
I put some sacrete under each post then filled the holes with sacrete with a hose going. My boys added the concrete while I leveled the post while making sure it was up against the string line. Not very scientific but it works. :)
I finally got the lights done in the barn. Each light is 18,000 lumens with 14 in the main area. I still need some plugs and lights over the work bench and the electrical work will be done for the most part.
They are very bright and I'm happy with them.
/ The last Barn. (maybe) #133
LED high bays? Are they dimmable?
/ The last Barn. (maybe) #135
Amazing barn build, and beautiful property. I can't see more than 20' out of my doors except forest, which is pretty in its own way.
Where do you all shoot around there? I was envisioning a range behind your barn.
Take care and be in good health, thanks for sharing.
I have miles of National Forest just behind my house and I can shoot all I want. No need to load wheelers or side by side up just drive it right from the house.
/ The last Barn. (maybe) #139
whoa, nice video to help understand the building assembly process. You had a lot of good helpers!!
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
Case IH STX 375 (A64126)
Case IH STX 375...
275 Gal Chemical Container (A64127)
275 Gal Chemical...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
