lostcreekranch
Super Member
- Joined
- Dec 14, 2012
- Messages
- 8,078
- Location
- Austin County, Texas
- Tractor
- NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
I was raking with the bottom tines backward (smooth) and forward (sifting). I also have the box blade on for counter weight and it has a row of ripper tines, a.k.a. rake. However, I had to disconnect one top and tilt on the box blade for the grapple. Do they make a "Y" valved splitter for the hydraulic lines? I don't mind getting off the tractor to turn a valve but I do mind making sure all the pressure is off then yanking two lines out and the connecting two other lines.
Have you considered adding a true 3rd function diverter valve off of your power beyond to operate your grapple. We put the WR Long 3rd function on the Hew Holland for the grapple. You get a new handle for your FEL joystick with a thumb rocker switch to open / close the grapple. Think it's much easier than having to move your hand to rear remote handle and you don't lose use of your top & tilt.
