Swale filling
/ Swale filling #1
Haneyman
John Deere 3038e
Got a swale by the driveway culvert from the highway to the field to direct water into the culvert.
I would like to fill this and add a vertical drain down to the culvert with a grate over it.
Similar to a riser but for a water meter but 3 feet high and able to percolate water from the sides if possible.
Any suggestions?
Thanks,Mike
/ Swale filling #2
I don't think anyone can offer much advice without seeing a picture or two. A meter? You lost me there.
/ Swale filling
Thanks,Mike[/QUOTE]
Can someone direct me how to post a picture to this thread
/ Swale filling #4
I can only help for a pc. Click the third icon from the right. It should be self explanatory after that.
/ Swale filling
Please see the attached picture of the swale I wish to fill
Thanks,Mike
/ Swale filling #6
GREAT! So you want to level out the terrain and pump the water out?
/ Swale filling #7
Assuming this is on the high end of the culvert?
I think he is wanting to install a catch basin raising the grade (i.e., riser)...no clue why to allow it to perc water though...
/ Swale filling
What I want is to fill in around a catch basin that will allow water to flow into the culvert.
The culvert end in the picture is the high end so water flows to the other side.
It’s the catch basin I’m wanting to construct.
Sorry I’m having trouble making myself understood.
Thanks,Mike
/ Swale filling
I was thinking if it let water perk through the sides of the new catch basin it would drain water through the fill as well as surface water entering through a top grate.
/ Swale filling #10
Do you get ice and snow? That can be a game changer when designing such things. Spring thaw and all.
Personally, I am doing something similar and totally unable to find any surplus concrete storm catch basins or cast sewer grates. Frustrating!
/ Swale filling
Here痴 a crude markup
/ Swale filling #12
Let me ask you this? Is that your land or right of way? I know our municipality is very sticky over such matters. A friend and neighbor wanted to fill in a slight ditch to gain better access to a field and the municipality said no way. Excavate and put in a culvert (at your expense) , if you want to have a level approach.
/ Swale filling #13
If I was going to do something like that I would lay a perforated pipe with gravel over and under in the existing swale pitched toward the catch basin (riser)...so it flows into it...(i.e., dry-well)
/ Swale filling
Yes western Kentucky here so it does rarely hit -20F
/ Swale filling
There won’t be any trouble with authority here.
/ Swale filling
My thought was a vertical perforated pipe surrounded by large gravel that water could flow through.
If capped with a suitable grate it would allow me to drive over it.
No idea where I could get either the perforated pipe twelve inches in diameter by three foot tall or a grate to cover it.
It would need to be grated at the top because we get rain downpours here that would overflow a dry well.
/ Swale filling #17
I would suggest a plastic 30gal drum for your vertical pipe butted up to the concrete tile. Cut a round hole for the tile and if too tall, either sink it further or cut the top off. If you perforate the sides, use a circular or rip saw for the slits. Anything bigger than a slit and I have problems with soil erosion on the sidewalls. Your grate could be welded 1/2" rebar or any other steel available.
/ Swale filling #18
You are just trying to widen the driveway/road, right?
If so, I would just extend the pipe out 3-5 feet and cover it with the fill being slightly sloped to drain toward the new end of the culvert and leave it at that.
Aaron Z
/ Swale filling #19
Construction supply stores sell catch basins and lids designed for traffic. Regular pipe set vertical is not designed to support traffic
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
PORTABLE OFFICE WITH BATHROOM (A67714)
PORTABLE OFFICE...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
(INOP) 2005 CATERPILLAR 535B SKIDDER (A65056)
(INOP) 2005...
