Swale filling
   / Swale filling #1
Haneyman
Member
John Deere 3038e
Got a swale by the driveway culvert from the highway to the field to direct water into the culvert.
I would like to fill this and add a vertical drain down to the culvert with a grate over it.
Similar to a riser but for a water meter but 3 feet high and able to percolate water from the sides if possible.
Any suggestions?
Thanks,Mike
   / Swale filling #2
I don't think anyone can offer much advice without seeing a picture or two. A meter? You lost me there.
   / Swale filling
Thanks,Mike[/QUOTE]
Can someone direct me how to post a picture to this thread
   / Swale filling #4
I can only help for a pc. Click the third icon from the right. It should be self explanatory after that.
   / Swale filling
Please see the attached picture of the swale I wish to fill
Thanks,Mike
   / Swale filling #6
GREAT! So you want to level out the terrain and pump the water out?
   / Swale filling #7
Assuming this is on the high end of the culvert?
I think he is wanting to install a catch basin raising the grade (i.e., riser)...no clue why to allow it to perc water though...
   / Swale filling
What I want is to fill in around a catch basin that will allow water to flow into the culvert.
The culvert end in the picture is the high end so water flows to the other side.
It’s the catch basin I’m wanting to construct.
Sorry I’m having trouble making myself understood.
Thanks,Mike
   / Swale filling
I was thinking if it let water perk through the sides of the new catch basin it would drain water through the fill as well as surface water entering through a top grate.
   / Swale filling #10
Do you get ice and snow? That can be a game changer when designing such things. Spring thaw and all.
Personally, I am doing something similar and totally unable to find any surplus concrete storm catch basins or cast sewer grates. Frustrating!
1983 Case 580D (A47477)
1983 Case 580D...
Year: 2005 Make: Autocar Model: WXR Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: Dr... (A55852)
Year: 2005 Make...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
