Stupid Things I Have Done
/ Stupid Things I Have Done #481
The only time I'll wear my wedding band at work is if I know I'm gonna be in meetings or a classroom setting all day.im a mechanic and have seen photos of the after effects of someone catching their ring.
My first weeding band was mailed out with some phone bills (working theory) the replacement lived in drawer until my wife lost hers and started wearing it.
It's been 35 years and still going....
/ Stupid Things I Have Done #482
This is really stupid.
We just moved into a vacation place in Florida. Great weather and never had the heater on. Had the a/c going a few times.
Last week it got a little cool and my wife turned on the heater. I go outside and hear the a/c unit fan motor going. Thought my wife mistakenly turned on the a/c v. heat.
Go inside and see the heat was indeed on.
Huh?
Call the a/c place and say something is wrong.
The heat is on but the outside a/c unit is running.
The nice tech says - “sir, you have a heat pump. The outside unit always runs when the heat is on”.
Sure enough.
Would have only felt more stupid had the guy actually came to the house.
Never had a heat pump before.
Not being used to a heat pump in our last house I did something similar
In the winter, we had the heat running.
Was outside and walked past the unit just as it went into defrost mode.
Well all of a sudden the unit let out this God awful squeal
Scared the living daylights out of me. I thought the motor was fixing to seize.
I freaked, call the heating and air conditioning company and explained what was going on.
Guy asked if the motor started running again???
I said yes, as a matter of fact it did.
That's when he explained about the defrost mode when it's set to heat.
Wow. Glad you let me know. I haven’t heard that yet!
/ Stupid Things I Have Done #488
The simplest way to explain it is the unit runs one direction while heating. The opposite direction when cooling.
It's basically switching where it bleeds off the access heat. Whether it's inside or out depends on whether it's heating or cooling.
When it's set to heat, the outside unit is basically being the AC unit and it's bleeding off the heat generated inside your home and the cold outside.
The outside unit will switch itself from heat to cool automatically to defrost the outside unit.
The noise is the sudden stop and start back up when it switches from heat to cool outside.
Inside during the defrost cycle, it utilizes the heat strips inside so it doesn't start cooling down your home.
/ Stupid Things I Have Done #489
I caught mine on a hot wire decades ago and it was the second time. If you have the time, the scarring and discoloration of your finger goes away in about 15 years. Haven't worn one since. :)
/ Stupid Things I Have Done #490
Coworker did that when I worked for an alarm company.
Had a coworker also crush his ring when I worked for the carpenters union in my mid 20's
Took three guys to hold him down to cut it off. And that's after we called his wife and she came to the jobsite to talk some sense into him. She said grab him and cut the ring off
He was dead set on not taking off his wedding band it meant so much to him.
His wife told him, it won't mean much if he loses his ring finger because he's being stubborn.
An employee with the company I currently work for caught his ring when he jumped out of a scissor lift.
He shared the after photos on the companies Facebook site. I actually printed off the photos and shared them in a morning meeting since we had a couple guys that wouldn't abide by the no jewelry policy at work.
Those photos will set you straight
/ Stupid Things I Have Done #491
Speaking of mangled fingers lots of stories lol Driving a fork truck in a crowded boat yard made a sharp turn and like a moron for more than just one reason used to put my hand out holding he top of roll cage like a grab handle crushed my hand between roll cage and a boat hull cuz they all are flared out somewhat, fortunately for the boat my hand provided a nice buffer and I only had to clean the blood off the hull from my now nailless mangled fingers.
/ Stupid Things I Have Done #492
Back in the 70s when I was working on trucks and construction equipment, I had to have my wedding ring cut off twice. After the second one, I didn't wear one.
/ Stupid Things I Have Done #494
I switched over to wearing a silicone rubber one for awhile. Actually liked it, but they stretch and get loose over time, requiring periodic replacement. Now I just keep the ring in a drawer when working in the shop or outside, and only put it on when donning dress clothes for business, dinners, or church.
/ Stupid Things I Have Done #495
......used to put my hand out holding he top of roll cage like a grab handle.....
I can relate. Done the same thing backing up on a fork lift to get to the door opener (being too lazy to get off the machine) Had my hand on the ROP and hit the door track, didn't hurt the track but sure did hurt my fingers.
/ Stupid Things I Have Done #496
Huh?
Sure enough.
When we moved here about 25 years ago, there was an air source heat pump installed. We have no natural or LP gas, so backup is resistance heat. That heat pump was worthless when it got down to 10 degrees. The electric bills were killing us, so we got rid of it and installed geothermal. We are much happier with the ground source heat pump, no defrosting is necessary and the electric bill is half of what it used to be.
/ Stupid Things I Have Done #497
When you hung up he told his coworker:
Damn Yankees, don't know anything."
/ Stupid Things I Have Done #498
How many holes did they have to drill? They are doing one of them on This Old House and I can’t remember but I think they drilled eight holes 800’ deep, that can’t be cheap.
/ Stupid Things I Have Done #499
I had actually lived over 20 years in the south. But never had a place that had a heat pump. Both houses in Florida, and my apartment in Arkansas had gas heat, and a stand alone ac unit.
The house I bought in Arkansas was the first one with a heat pump.
/ Stupid Things I Have Done #500
Well, they never over-do anything on TOH. :rolleyes::p There are entire threads on other forums about homeowners being driven broke by participating in one of that show’s renovations. Guilty pleasure, I used to watch it every weekend, but they did go a bit over the top in recent years.
I’ll ask two of my neighbors who have gotten new deep well geo systems in the last ten years, but I think both have fewer and shallower holes than that, in 5000 and 8000 sq ft, respectively.
UNUSED IRANCH IRTPL 10000Ib TWO-POST CARLIFT (A60432)
UNUSED IRANCH...
2018 HINO SA (A58214)
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
TEST YOUR BID BUTTON! (A60432)
TEST YOUR BID...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60432)
KNOW BEFORE YOU...
