Stump grinder build
/ Stump grinder build #11
Right on, looking forward to more build progress.
Great idea! Nice having your work resources.
/ Stump grinder build #12
Very cool, this is exactly what I have been collecting parts to build, I was planning on a 1in thick flywheel and was still working out the number of teeth.
Are you using the 700 series? Interested in seeing style pockets and pattern you're using.
What size tractor are you planning on using this on?
Yeah, I’m using the 700 series teeth.
For now I’m using 3 sets of angled and 3 sets of straight. I added an extra 6 sets of holes offset 1/2 deeper on the wheel to add more teeth if required.
I had planned to go with a 3/4 inch thick wheel, but the mounting bolts I ordered would only accommodate the 5/8 inch plate.
I plan to run it on my 30hp JD 4310
Just flying by the seat of my pants and spending way too much money. The teeth alone 500$ Canadian pesos’
/ Stump grinder build #14
I'm looking at doing an 18tooth setup (the teeth are a little cheaper here in the good ol USA).
I found machine setups are more affordable so using a Bandit 2100xp setup which uses 6 straight and 12 angled teeth and has the bolts for a 1in flywheel.
I don't have a peice of 1in plate large enough right now, so planning on using 2 5/8 peices turned and bolted together with the hub and teeth.
Are you just welding the gearbox hub onto the flywheel? My plan was to make a hub that has a the gearbox hub welded to it that will then bolt to the flywheel.
I took the notion to build this stupid thing looking at American websites, thinking “how much more can it cost to source this stuff in Canada”. Gag... I’m actually scared to know how much it is to purchase a Woods model grinder for fear I’ve spent more to build it. Lol
I wish I could have found the teeth in a kit like you did.
I do plan to weld the hub to the fly wheel. The output on my gearbox has just a key way on it. If I where to buy again I would have gotten one with a splined output.
/ Stump grinder build #17
Ah got ya, my gearbox is a tapered spline (brush hog style), otherwise I would have just machined a new hub for it.
The place I'm looking at getting the teeth from is treestuff.com. It's about $375 usd for the 18tooth setup I'm looking at.
Wish I had access to a laser and cnc brake, but at least I have a cnc plasma and a little press brake.
/ Stump grinder build #18
Cool project. Keep the photos coming. :thumbsup:
A little progress today and last night. I added the cutting wheel shroud. I bought 3/16 material for it. Boy did I over estimate the thickness. I had to cut half way through it with angle grinder in 18 places. I then bent it about 10 degrees at each cut.
I couldn’t find a decent way to clamp it. Ended up wrestling with it as I’d try to tack it.
Far from perfect but I can live with it.
I tried to find a slip roller but know one had one that could do stuff 5 inches wide.
/ Stump grinder build #20
Did you use 3/16 for the gearbox mount also?
2015 Kenworth T880 (A60462)
2015 Kenworth T880...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2005 DRAGON ROLL-OFF  TRAILER (A60736)
2005 DRAGON...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
SDLanch SDLGM1220F (A60463)
SDLanch SDLGM1220F...
