Snow Attachments snow blower tip speed
   / snow blower tip speed #1
19rocky44
cubcadet 782d
I am trying to mount one brand snow blower on another brand tractor. I think I have most things figured out except the RPM needed to turn the 14" impeller fast enough to get the tip speed required to throw snow a reasonable distance. All knowledgeable answers will be very much appreciated.
Roger
   / snow blower tip speed #2
Roger
Are you talking about a single stage front mounted blower?
A blower driven by an electric clutch on the gas engine motor?
Typically, a blower manufacturer will make product for many tractor brands. The big difference between a New Holland and a Cub Cadet blower will be the paint color.
Gas tractor motors are limited to a few brands such as Kohler, Kawasaki. These motors are built to standards so should a new motor be needed, the mounting bolt holes, shaft size and length will also be following an industry standard.
Dave M7040
   / snow blower tip speed #3
as far as i know, all rear mounted, 3 point pto blowers are designed for 540 RPM. thats standard pto speed. every blower ive ever used is run at that speed. even ones with no name plates on them.
   / snow blower tip speed #4
Most rear mount pto driven blowers operate at 540 rpm. Smaller front mounts usually run 2000 rpm to a gearbox, reduces it to 540 impeller speed.
   / snow blower tip speed #5
What brand and model snow blower? What brand and model tractor?
How many horse power is the tractor.
   / snow blower tip speed #6
Yup. 540 on a PTO driven is standard.
On a snowblower it's all about the fan speed. The larger the fan diameter the better off you will be.
   / snow blower tip speed #7
Are you saying the snowblower is NOT PTO driven?
That’s it’s not designed to run at 540 rpm input?
Roger
The blower is a two stage that will be driven by a pto, drive shaft and thanks for your reply.
My PTO is a 2 speed of 1100 or 2500 RPM. Sounds like I need to reduce my speed by 50%. Thanks for your reply.
The snowblower is a old cub cadet 190-450 and the tractor is a f2400 kubota rated at 24 HP but not sure of the PTO rating. I also realize the blower is to narrow for the tractor so I will be reversing the rims to compensate for it this year hope this sounds like my bases are covered and thank you for your reply
