Quick hitch recommendations
/ Quick hitch recommendations #21
The problems with extending the top hook on the QH is make it stick out further than the lower hooks. So you have to run your toplink link shorter to compensate. On a bigger tractor, with a longer toplink you have plenty adjustment so it is not much of a problem. On a smaller tractor like a BX with a short toplink, shortened all the way is not much off of most implements running "level." If I would have had it do over again on my HF QH I would have welded the hook directly to the QH.
Maybe someone like Everything Attachments will make a QH with a fixed top hook like the old imatch someday.
/ Quick hitch recommendations #24
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
10.5' Telescoping Ladder (A66408)
10.5' Telescoping...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
