Quick hitch recommendations
/ Quick hitch recommendations #21
The problems with extending the top hook on the QH is make it stick out further than the lower hooks. So you have to run your toplink link shorter to compensate. On a bigger tractor, with a longer toplink you have plenty adjustment so it is not much of a problem. On a smaller tractor like a BX with a short toplink, shortened all the way is not much off of most implements running "level." If I would have had it do over again on my HF QH I would have welded the hook directly to the QH.
Maybe someone like Everything Attachments will make a QH with a fixed top hook like the old imatch someday.
/ Quick hitch recommendations #24
Arrow Board (A62613)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
