Post Trenching Trench Cleanout - MicroHoe
   / Post Trenching Trench Cleanout - MicroHoe #31
You could weld some bolts to the side up near the top. and make the wings so they will slide up and down. Once set, just tighten the locknuts on the bolts.
   / Post Trenching Trench Cleanout - MicroHoe #32
While you are at it, why not make a gizmo to backfill the trench, something like a V shaped flange to slide the dirt back in the trench, and level things out. You might could use one of those mound makers that is an accessories for the Troybuilt tillers.
</font><font color="blue" class="small">( You could weld some bolts to the side up near the top. and make the wings so they will slide up and down. Once set, just tighten the locknuts on the bolts. )</font>
I can't quite visualize that. Could you explain it a little more.
Bob Rip
   / Post Trenching Trench Cleanout - MicroHoe #34
This accessory is hooked on the back of the tiller to mound up the dirt that was just tilled. Otherwise, it makes nice round hills and valleys for the water to run off. A simple V scraper will also work, laying horizontally on the ground and pushed or pulled, depending on the way you mount it.
   / Post Trenching Trench Cleanout - MicroHoe #35
The wings would look like this. 8 in angle iron with a slot cut in one side and bolted on, one on each side. In the float made. the trencher would sit on the top of the ground and limit your depth, and smooth out the top of the trench.
I haven't figured out how to get a drawing in these post.
   / Post Trenching Trench Cleanout - MicroHoe #36
Here's a picture of a Troy-Bilt Hiller-Furrower
   / Post Trenching Trench Cleanout - MicroHoe #37
Thanks Kent.
Yep, that's it, once mounted, just drag it over your trench to push the dirt to the center and mound it , because it will continue to settle.
I took a picture of a PT hydraulic drawing once and uploaded it. This worked pretty well.
Bob Rip
Thanks Kent. That looks pretty good. I have been using the 4 in 1 bucket, but this probably works better. I will think about it.
Bob Rip
   / Post Trenching Trench Cleanout - MicroHoe #40
Very nice job. Along with you and J.J.s idea of a trench filler I think you have the project covered.
Would like to see this in operation if possible.
PJ
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
