Old post about burying wire...
/ Old post about burying wire... #1
adegiulio
Red Hook NY
JD 4310
A year or two ago, someone posted about an ingenious way to bury wire. It involved a piece of pvc pipe attached to a ripper of some sort. As the ripper opened up the ground, the wire was run through the pvc and deposited in the trench. The trench then closed right back up like magic.
I've searched and searched, but can't find it. Can anyone help find this post? Thanks for the help
/ Old post about burying wire... #5
I lowered the middle scarifer blade on my box blade to run a shallow under ground dog pen wire. I used duct tape to affix a 1/2 inch piece of pvc pipe with a 90 degree elbox on the bottom. I placed the roll of wire on a long bolt used to attach the top link to the box blade.
The first time I put down an under ground dog pen wire with a rented trencher. It took me 30 minutes with the trencher and half a day to stick the wire down into the trence by hand. I did the entire job in an hour with the old duct taped scarifer.
/ Old post about burying wire... #6
Jimhoodag, what guage wire did you run for the dog pen? We just moved and I too the invisible fence trasmitter with me. I now need to put a wire in the new house but I forgot to measure the guage wire they use. The BB sounds like a good idea. I am barrowing one right now so I can use that instead of buying a middle buster like many others have used.
Eric
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
