New Building!
   / New Building!
Got it done to the point where I can start using it. I still need to finish sealing, paint add skirting, a bit of dirt work, and add some rock around it. I'll probably slow down a bit now that it has a roof and I can use it.
This was the first time I put on a roof on my own. I'm not a fan of heights, but it went pretty well.
   / New Building! #12
Good job. Looks like a perfect fit for your mower!!!
   / New Building! #13
Good job! Nothing like having a place to put stuff.
   / New Building!
I finished this up a couple of weeks ago, but I've been slacking on posting the pictures. I put down weed barrier for the rock and added scribed pieces of cement-board siding to keep critters out. I went with cement board to make sure it wouldn't pull up moisture. It worked out pretty well. A grinder with a masonry cutter (and a good dust mask) was the easiest way to cut it to the profile.
   / New Building! #16
Like the red paint also. The building looks good.
What kind of paint did you use. Every time I buy a barn red paint it doesnt look red to me.
But some darker shade.
   / New Building!
I just got exterior paint from Lowes. I forget the exact color name. I just grabbed a bunch of red samples and let my wife pick. I was worried it was too dark until I got the white trim done.
   / New Building! #18
Thanks I will check Lowes out. Will show them your pics and tell them thats the color I wantšŸ˜›
The white trim really sets it off.
   / New Building! #19
its purdy, i had one like this for many years i ended up putting gable vents in it with screens to keep out the mud daubers i ran electric as well to keep my batteries on trickle and have lights so i could piddle in it and work on projects. Do you plan on insulating/lights or do you have a different barn/shop for that stuff?
   / New Building!
This one is just for storage. I'm getting a shop built later this summer.
2012 Buck Verano Sedan (A55758)
2012 Buck Verano...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
New Idea 310 1-Row Cornpicker (A50775)
New Idea 310 1-Row...
S/N: 3356916 ***Roof is NOT attached*** (A55853)
S/N: 3356916...
