New Building!
/ New Building! #1
lincmercguy
Colorado
JD 5105, JD 5055E
Or at least a new shed. I got one of the shed kits from Lowes and unloaded it with my 5105. I was pretty impressed with how it handled 1400lbs. I could probably use some more weight in the back, the rear tires were a little light (had the box blade on the back). I just needed to get it off of the trailer, so it wasn't too big of a deal. Nice to have a tractor and forks.
/ New Building! #2
Never actually seen one of their kits all packaged up and on a pallet. What type of foundation are you putting it on?
/ New Building!
I have a dirt pad that I compressed last year. I dug solid concrete blocks into that, and made sure they were all level with each other. On top of those are 4x4s as the manufacturer recommended.
I'm about halfway through construction. I'm pretty impressed with the kit except for the pieces that could be 10' but are not. I just bought some 10' 2x4s to replace them where it makes sense.
/ New Building! #4
Take a lot of pics. We love tagging along!!!
/ New Building!
Here's the blocks being dug into the ground to where they're all level. My compacting work seemed to do well, it was hard as heck to dig down a few inches by hand. Our soil here is sandy, so it wasn't due to clay, lol.
Per the manufacturer's recommendation, I put down 4x4's. I could only find 8' ones that weren't twisted to heck, so I doubled them up like this.
Here's the floor in place. The kit came with an 8x10 floor kit and a 4x10 floor kit extension. The long pieces from the kit were supposed to be made from 4' and 6' pieces. I bought four 10' 2x4's and replaced them. Something to keep in mind, the treated pieces that come with the kit are 3 3/8" instead of 3 1/2" wide. It worked for me because the long 2x4's aren't resting on the 4x4's, so they just hang down a bit further. If I knew this before, I would have cut them to the same width.
One advantage of doing this is the extra pieces left gave me enough to make the floor joists 12" OC instead of 16" OC. I would recommend the same for anyone who gets one of these kits. I bolted the two floor "kits" together before the OSB went on.
I know the picture puts things at a funny angle, but it's square and level.
The last picture makes it look like I didn't get anything done, lol. I have an awesome neighbor that came over to help me for a good chunk of the weekend. Using a nailgun and no-drill screws makes things go much quicker. Unpacking and sorting this kit by itself is quite a bit of work. We got the four main walls framed, racked, and sided (the kit comes with pre-cut combo OSB/siding panels that you put on while building each wall to rack the wall.
I also replaced the top and bottom 2x4 pieces of the end walls with continuous 10' 2x4's intead of the 6' and 4' pieces.
At the end of the day, we stacked everything onto the floor and tarped it for the rain this week.
/ New Building! #6
Following the build and reading about your soil reminded me of testing soil to see what we really have. My sandy soil, as I thought, surprised me of the amount of clay it contained. This isn't about your present build but if you ever need to pour a little concrete that may be a different matter. A simple test and cost is $0.0 if you discount the jar and water. Shake a sample of soil and water vigorously and read in 24 hours.
/ New Building! #7
Hardest ground I ever dug was in Saudi Arabia near the Iraq border. No vegetation in site. Appeared to be desert sand.
/ New Building! #8
My sandy soil, as I thought, surprised me of the amount of clay it contained. ... Shake a sample of soil and water vigorously and read in 24 hours.
But, isn't that test showing that you have almost no clay? You have mostly sand that settled at the bottom. The clay portion is mostly water, no?
/ New Building!
Was a little busy this weekend.
/ New Building! #10
Lookin good!!! Thanks for the update!!!
/ New Building!
Got it done to the point where I can start using it. I still need to finish sealing, paint add skirting, a bit of dirt work, and add some rock around it. I'll probably slow down a bit now that it has a roof and I can use it.
This was the first time I put on a roof on my own. I'm not a fan of heights, but it went pretty well.
/ New Building! #12
Good job. Looks like a perfect fit for your mower!!!
/ New Building! #13
Good job! Nothing like having a place to put stuff.
/ New Building!
I finished this up a couple of weeks ago, but I've been slacking on posting the pictures. I put down weed barrier for the rock and added scribed pieces of cement-board siding to keep critters out. I went with cement board to make sure it wouldn't pull up moisture. It worked out pretty well. A grinder with a masonry cutter (and a good dust mask) was the easiest way to cut it to the profile.
/ New Building! #16
Like the red paint also. The building looks good.
What kind of paint did you use. Every time I buy a barn red paint it doesnt look red to me.
But some darker shade.
/ New Building!
I just got exterior paint from Lowes. I forget the exact color name. I just grabbed a bunch of red samples and let my wife pick. I was worried it was too dark until I got the white trim done.
/ New Building! #18
Thanks I will check Lowes out. Will show them your pics and tell them thats the color I want😛
The white trim really sets it off.
/ New Building! #19
its purdy, i had one like this for many years i ended up putting gable vents in it with screens to keep out the mud daubers i ran electric as well to keep my batteries on trickle and have lights so i could piddle in it and work on projects. Do you plan on insulating/lights or do you have a different barn/shop for that stuff?
/ New Building!
This one is just for storage. I'm getting a shop built later this summer.
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2015 Kubota M6-131 131HP 4WD Agricultural Tractor (A66734)
2015 Kubota M6-131...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
2012 CHEVROLET SILVERADO 1500 (A67714)
2012 CHEVROLET...
2014 Chrysler 200 Sedan (A66738)
2014 Chrysler 200...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
