MX5800 tire pressure
/ MX5800 tire pressure #1
coolbrze
VA
Kubota MX5800
What should the tire pressures be (front & rear) for my MX5800 HST w/ R4s? The front are "foam" filled & the rears are filled for ballast weight if that changes anything? Appreciate it!
/ MX5800 tire pressure #2
If the fronts are foam filled you're going to have a hard time adjusting the air pressure.
For filled rears I like to lift my heaviest 3PT implement up then release or add pressure until the outside edge of the tread barely touches on a flat solid surface.
/ MX5800 tire pressure #4
I run my front tires at 40 psi. No foam - air only. I run my rear tires at 16 psi. Rears are filled with Rim Guard. Both front and rear are R-1's - six ply.
16 psi in the rears give me a full chevron contact patch on hard, flat ground.
40 psi in the front because I lift "heavy" with my grapple.
/ MX5800 tire pressure #5
The only thing I’ll add is: Maximum pressure is listed on your tires sidewall… don’t exceed it…
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
76in. Skeleton Skid Steer Grapple (A65640)
76in. Skeleton...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
