MX5800 tire pressure
/ MX5800 tire pressure #1
coolbrze
VA
Kubota MX5800
What should the tire pressures be (front & rear) for my MX5800 HST w/ R4s? The front are "foam" filled & the rears are filled for ballast weight if that changes anything? Appreciate it!
/ MX5800 tire pressure #2
If the fronts are foam filled you're going to have a hard time adjusting the air pressure.
For filled rears I like to lift my heaviest 3PT implement up then release or add pressure until the outside edge of the tread barely touches on a flat solid surface.
/ MX5800 tire pressure #4
I run my front tires at 40 psi. No foam - air only. I run my rear tires at 16 psi. Rears are filled with Rim Guard. Both front and rear are R-1's - six ply.
16 psi in the rears give me a full chevron contact patch on hard, flat ground.
40 psi in the front because I lift "heavy" with my grapple.
/ MX5800 tire pressure #5
The only thing I’ll add is: Maximum pressure is listed on your tires sidewall… don’t exceed it…
Gasoline Concrete Mixer 8.0 Honda (A62679)
Gasoline Concrete...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Landhonor 48" Galvinized Fence (A66408)
Landhonor 48"...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
Asphalt Melter (A61572)
Asphalt Melter...
