John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,779
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
You apparently have not dealt with how hard the ice and snow freezes to the pavement up here... and when it is down below 0˚F, rock salt is completely ineffective in helping to loosen it.Ok, even with packed snow, something is not right if you have to use so much down pressure.
Any down pressure should not take the front end off the ground. You are losing a lot of tractive force.
It should be enough to provide just enough pressure to insure surface contact with the desired bucket angle. With enough traction, the bucket gets under the load and as it proceeds forward, the weight of the snow in the bucket itself, provides further ground contact stability.
Not trying to be insulting. Have confronted this occasion with myself and many customers.
I try to avoid lifting the front wheels, but sometimes even if I do lift them, the lip of the loader just slides along on top of the ice - regardless of the bucket angle. Once things warm up a bit, and the ice is just sitting on top of the pavement, rather than frozen to it, you are correct that it does not take much pressure.
