MX5800 tire pressure
/ MX5800 tire pressure #1
coolbrze
VA
Kubota MX5800
What should the tire pressures be (front & rear) for my MX5800 HST w/ R4s? The front are "foam" filled & the rears are filled for ballast weight if that changes anything? Appreciate it!
/ MX5800 tire pressure #2
If the fronts are foam filled you're going to have a hard time adjusting the air pressure.
For filled rears I like to lift my heaviest 3PT implement up then release or add pressure until the outside edge of the tread barely touches on a flat solid surface.
/ MX5800 tire pressure #4
I run my front tires at 40 psi. No foam - air only. I run my rear tires at 16 psi. Rears are filled with Rim Guard. Both front and rear are R-1's - six ply.
16 psi in the rears give me a full chevron contact patch on hard, flat ground.
40 psi in the front because I lift "heavy" with my grapple.
/ MX5800 tire pressure #5
The only thing I’ll add is: Maximum pressure is listed on your tires sidewall… don’t exceed it…
Sudenga 10 x 63 Portable Swing-away Auger (A66408)
Sudenga 10 x 63...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2012 KENWORTH T370 CAB & CHASSIS (A65643)
2012 KENWORTH T370...
Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
Warren Power...
Massey Ferguson Model 66 Hay Rake (A65640)
Massey Ferguson...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
