Box Scraper Land Leveler Build
/ Land Leveler Build #21
I have a Land Pride GS2584. At 800# it is a lightweight compared to what the OP is building. The replaceable cutting blades( 2 ) are mounted on angle iron. So the cutting blades are at a 45 degree angle - relative to the ground. Their angle across the unit would be 15 to 20 degrees - a guess. Angled across the unit because it's probably a more efficient way to cut into the dirt.
Mine has scarifiers. ABSOLUTELY NECESSARY to get anything accomplished on my rock hard gravel driveway. Otherwise - without first using the scarifiers - the unit just bounces along behind the tractor. For three years I tried to get the LPGS to work - no joy. Then in desperation I used the scarifiers. It is now a very useful implement.
I drop the scarifiers about an inch and a half below the following blades/side skids. It scarifies and the blades level it out very nicely. In my situation there would be no need for a rear gate.
As an experiment - I've put 400#( a big pine log ) on top of the LPGS. It DID make the unit cut into the driveway - somewhat. Not near as good as using the scarifiers.
JMHO - if you are dealing with soft soil or a "soft" driveway - scarifiers may not be required. Otherwise - it will be a required addition.
BTW - what is your estimate of the final weight??
Kubota L2501 (A60462)
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
2023 CATERPILLAR 279D3 SKID STEER (A62129)
2023 CATERPILLAR...
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
