Kioti ck25 4/4 not working
   / Kioti ck25 4/4 not working #1
Leonard malone
Kioti ck 25
The front axle is leaking fluid and the front wheel drive stopped working. If I continue to use tractor in 2 wheel drive will it do more damage to the front axle. Wondering if I could or should remove front drive shaft. Any thoughts would be appreciated. Thanks Len
   / Kioti ck25 4/4 not working #2
I'm not that knowledgeable on tractor front axle types, but I suspect most, if not all of the components are rotating whether the 4 wheel drive is engaged or not.
I would not use the tractor until repaired
   / Kioti ck25 4/4 not working #3
Yes, all the front axle drive train components keep spinning even with the 4x4 disengaged, so if there is, for instance, a bad bearing or broken gear, it can cause even more damage to the rest of the axle.
   / Kioti ck25 4/4 not working #4
Is it mechanical engaging 4x4 or is there an electronic switch to engage 4x4.
If its electronic it may be a simple relay issue.
Thanks all. Guess I better fix it before I make things worse.
(13) WOOD PALLETS (A60432)
(13) WOOD PALLETS...
2008 Ford F-250 Reading Service Truck (A59230)
2008 Ford F-250...
2018 Toyota C-HR SUV (A59231)
2018 Toyota C-HR...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
FUEL CELL (A58214)
FUEL CELL (A58214)
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
