Internet Dish Wiring
   / Internet Dish Wiring
since you are redoing the roof, put in a 2" PVC pipe like you would see for a plumbing vent, with a boot to seal it at the roof. put a couple of elbows on the top to keep the rain out. after you get your wire through, foam the inside of the pipe to keep bugs and critters out.
That is a great idea, problem is they finished the roof yesterday. **** it
   / Internet Dish Wiring #12
If I had to penetrate the roof I'd do it with pvc like a plumbing vent, boot it and put a inverted trap on top.
Yep, I wish I would have thought of that before they finished the roof.
   / Internet Dish Wiring #14
Then I'd go with the vent like you were originally thinking.
   / Internet Dish Wiring #15
Would not be running the ground wire into the interior of the house....
   / Internet Dish Wiring #16
This right here, only I wouldn't foam it, in the event you need to access it again it is a PITA. You can stuff with insulating foam and it is easy to dig out again.
Go buy the boot from home depot or what ever when you buy the pipe. Use a hole saw to go through the roof, right under where the lap on the shingle is. Slide the base of the boot between the shingles until the hole lines up and stuff the pipe through from the bottom. Roof is fresh enough that the shingles should not have sealed yet, or if they did they will be easy to separate.
Or go through the roof vent as you mentioned, I would go from the bottom edge of the vent if it were me.
   / Internet Dish Wiring #17
There used to be sites online that would list where the sat's were in the sky. Before I started wacking holes in my roof I would check to see where the best spot was that you could get a clear vista. I walked around north of my house until I found a place real clear [ tall wood stick, level, and a homemade 'asmith or whatever device']. Then planted a 2" steel post, ran a 1" pvc conduit down the pipe and into the foundation, cemented a big circle around it so I could mow easy... then called the install guy. He came out, pulled in the two cables using the pull wire I had ready for him, set up the outside dish, and he was a happy camper. Me too... still like my sat TV...
Am I in the twilight zone or something. Once again, this is not satellite. It's line of sight to the west to a tower and it has to be on my roof to clear the tree line.
   / Internet Dish Wiring #20
I don't think this is satellite
Sorry OP I missed where someone had already suggested my method. But CreekyB is correct no issue adding a boot to a shingled roof.
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
2004 Hyundai Santa Fe SUV (A48082)
2004 Hyundai Santa...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
