hydraulics weak
/ hydraulics weak #1
adam davis
sabina ohio
john deere B
i have a john deere B that is a 1950 i need to no if i can use motor oil in the hydraulis? and how much it takes? were is the drain plug at on the tratcor?
/ hydraulics weak #8
jd gets 90$ for the paper maual, and a bit less for the one on cd.
the thin flimsy aftermarket I&T manual is 1/3rd that price.
both of them are good reads and worth t he money.
/ hydraulics weak #9
forgot to mention.. I'm at work now and not near my manuals, and it's been way too long since I worked on a B. :)
/ hydraulics weak #10
10w-30 is good. drain plug is just in front of filter cap about seven quarts don't use hydraulic oil fill through the breather on top on the side should be a petcock to check your level
/ hydraulics weak #11
on some styles there is no breather on the crankcase they have a fill plug in the gear cover on the pulley side
/ hydraulics weak #12
some styles don't have the breather on the crankcase cover they have a fill plug in the gear cover on the pulley side of the main case
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
Caterpillar 950F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 950F...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
