hydraulics weak
/ hydraulics weak #1
adam davis
sabina ohio
john deere B
i have a john deere B that is a 1950 i need to no if i can use motor oil in the hydraulis? and how much it takes? were is the drain plug at on the tratcor?
/ hydraulics weak #8
jd gets 90$ for the paper maual, and a bit less for the one on cd.
the thin flimsy aftermarket I&T manual is 1/3rd that price.
both of them are good reads and worth t he money.
/ hydraulics weak #9
forgot to mention.. I'm at work now and not near my manuals, and it's been way too long since I worked on a B. :)
/ hydraulics weak #10
10w-30 is good. drain plug is just in front of filter cap about seven quarts don't use hydraulic oil fill through the breather on top on the side should be a petcock to check your level
/ hydraulics weak #11
on some styles there is no breather on the crankcase they have a fill plug in the gear cover on the pulley side
/ hydraulics weak #12
some styles don't have the breather on the crankcase cover they have a fill plug in the gear cover on the pulley side of the main case
