hydraulics weak
/ hydraulics weak #1
adam davis
sabina ohio
john deere B
i have a john deere B that is a 1950 i need to no if i can use motor oil in the hydraulis? and how much it takes? were is the drain plug at on the tratcor?
/ hydraulics weak #8
jd gets 90$ for the paper maual, and a bit less for the one on cd.
the thin flimsy aftermarket I&T manual is 1/3rd that price.
both of them are good reads and worth t he money.
/ hydraulics weak #9
forgot to mention.. I'm at work now and not near my manuals, and it's been way too long since I worked on a B. :)
/ hydraulics weak #10
10w-30 is good. drain plug is just in front of filter cap about seven quarts don't use hydraulic oil fill through the breather on top on the side should be a petcock to check your level
/ hydraulics weak #11
on some styles there is no breather on the crankcase they have a fill plug in the gear cover on the pulley side
/ hydraulics weak #12
some styles don't have the breather on the crankcase cover they have a fill plug in the gear cover on the pulley side of the main case
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
JOHN DEERE 220 CENTER FOLD DISC HARROW (A63291)
JOHN DEERE 220...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
1985 23ft Mako Center Console Boat with 2011 28ft HMDE Trailer (A61574)
1985 23ft Mako...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
