Soldier415
Platinum Member
- Joined
- Sep 7, 2016
- Messages
- 693
- Location
- Vermont
- Tractor
- 2001 Kubota L3010GST. 2005 Kubota L3430HSTC
I had a similar experience but was not so lucky. This happened back in 2014. Needed to touch off a brush pile.
I knew Gas was not the right choice but thought I could mitigate the hazards
I normally use diesel or bar and chain oil but didn't have any. Had some 2 month old gas so spread that over the pile of branches and other yard waste, let it sit for 20 minutes for the vapors to disperse.
Unfortunately the top layer of the pile was burlap type screening you put down before mulch and it trapped the gasoline vapors in the pile. Went to light it and less than a foot away...WHUMP! Huge gasoline fireball enveloped me as I was right in front of a void in the side of the pile where vapors were trapped.
After the explosion while back pedaling I rubbed my hands all over my head rapidly to put out my hair which was on fire. Doing that also tore pieces of burnt skin off. Stopped dropped and rolled to put out my sweatshirt. Unfortunately doing that caused the burned skin to slough off my hand from the friction on the ground of rolling. Saw that the gas can was like 5-10 feet from the fire so I ran and grabbed it and moved it farther away.
Floored ATV to the house to look in the mirror. Took one look and knew this was really really ****ing bad and I would not be driving myself to the ER. Called 911, relayed situation and requested EMS for me and to roll fire to put out the brush pile so there wouldn't be an unattended fire. After 911 I put the dogs in their crates, locked the house and truck and went to wait for EMS in the driveway. Was doing tactical breathing to manage pain and keep myself from delving into shock.
Took 15 minutes for ambulance to get there, another 5 mins on scene to start an IV line and get vitals, then another 25 minute drive to the ER. This was the worst pain I have ever felt in my life.
At the ER I had to be knocked out and intubated/ventilated due to concerns about my airway, then transferred an hour away to the emergency burn unit. Incidentally, I woke up right as they started to intubate me. I was fully aware, yet paralyzed and could not breath. Not a pleasant experience
These pictures are of me after 2 days in the burn unit, with second degree burns covering almost all of my face, head and right hand. Mot of my hair was burned off, as were my eyebrows and eye lashes.
The recovery was extremely painful as I had to scrape dead burned skin off every morning. It is not worth it. Even if you have done it 99 times, the 100th may be the time it doesn't work for you.
