FEL mounted plows?
/ FEL mounted plows? #31
I had this kind of setup and found it to be too long overall. So I built a sub-frame and mounted the plow to the tractor and used the loader valave for the control.
Regards,
Chris
/ FEL mounted plows? #32
I have a 7.5 fisher that goes on the front of my L3700 SU. I had a plate welded to it so it was compatable with a SSQA. It works well and I can stack snow 12' up
/ FEL mounted plows? #33
Well after coming from a long stint at operating heavy equipment and now into a little bit of everything including snow clearing which I did with a 1993 GMC truck for 13 years but back in 2008 I decided to retire the GMC and get a tractor. I took the truck plow and designed and fabricated it to the then Kubota 4240 which I used for two years then went up to a Kubota 5740 and the plow went on that where it is today with no issues at all. If I had to do it over again I wouldn't change a thing. I have many videos on YouTube if you want to see it in motion.
/ FEL mounted plows? #34
That's a great set-up. I've seen some of your videos on Youtube. What is the purpose of the hooks on your blade quick attach? Moving the blade?
/ FEL mounted plows? #35
Thanks. The hooks are there because every now and then while I'm out snow clearing I find someone in the ditch so I use the nylon sling I have stored in the FEL tube to pull them out.
/ FEL mounted plows? #36
Good idea, I have trouble deciding where to put stuff like that, including shovel.
/ FEL mounted plows? #39
/ FEL mounted plows? #40
I run a 8' HD snowpusher with my tractor, no issues. These things are built to be used not to be a garage queen. CJ
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
TANK MANIFOLD (A58216)
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
