electrical/ pressure switch question
   / electrical/ pressure switch question #42
you've probably aready solved this: but here goes anyway: it could be wired like a oven is: one side of the 220V being there all the time, and the pump only runs, when the other leg is applied: then you would have 120V at the breaker box at all times: or like some have said, move your pressure tank closer to the pump: get one of the really small pressure tanks, put the switch on it, and install it close to the pump: OR put in a 120V pump: i have installed several 120V pumps and they last for years and years: a lot of folk will say a 220V pump uses less current, which is true, but if your wire is large enough to handle whatever the current is on a 120V pump, who cares!!!
heehaw
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2008 Ford F-750 SD Roll Off (A50860)
2008 Ford F-750 SD...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
Adams 8 Ton Weigh Hopper (A51039)
Adams 8 Ton Weigh...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
