Echo 590 or the X Series?
/ Echo 590 or the X Series? #61
This is exciting news, I'll have to check my (different models) Echo's👍
I love little common sense features like this.
The smaller saws like my CS top handle still require a 'Scrench' to loosen the fuel and oil caps. Only the larger (rear handle) saws have that feature, I believe.
Eddie, while we're spending your money, 😖 I'm certain that you have cordless tools and you know that (mostly) buying a new tool with batteries, the tool is usually close to free if you count the cost of the batteries by themselves.
I'm married to Makita, Amazon had a little saw that came with 4-5amp batteries that all my other tools use. Of course this included the saw and a dual charger for $350.
With no illusions of the battery saws capability I figured I couldn't go wrong.
Well every tool has its "place" and I'm impressed with it for little stuff. It's always put in the Gator for driving around my land, and it sips bar oil because it only pumps when the chain is spinning so you don't have to carry anything but the saw. I put it in the truck for wind storms knocking trees over but that's probably not a concern in TX.
I know guys with Milwaukee and Dewalt that appreciate theirs as well.
They're not going to compete with the big guys battery saws, but I don't expect it to and the last thing I want is another line of batteries to keep up with.
I'm also a Makita guy with a pretty good collection of Makita tools and batteries. I've thought about getting the cordless chainsaw, but haven't yet. I do use my cordless Sawzall with a pruning blade fairly often to cut up branches. It's also what my wife uses when she wants to prune our trees around the house.
My next Makita purchase will probably be their leaf blower. I want to have it in my tractor to blow off my batwing after I'm done mowing for the day.
/ Echo 590 or the X Series? #63
I bought the Bauer 20 volt cordless (small) blower (tool only 29 bucks) and it fits quite nicely behind the seat of my Kubota's. I use it to blow off the accumulated chaff from the round bailer as well as blow out the radiator and heat exchangers on the Kubota's while I'm in the field's running hay. Nice blower with a ton of air flow and it comes with a concentrator nozzle as well as a nozzle for inflating things like pool toys (that I have no use for anyway). Bauer also has a 20 volt 'sawsall' but I haven't acquired it...yet.
/ Echo 590 or the X Series? #64
My ongoing philosophy is... If you are already running Makita cordless tools, stick with them, or Ryobi or DeWalt or Milwaukee or whatever. In my case it's HF Bauer. All good IMO.
I will say that I've not had one tool failure with the Bauer stuff...yet and I have a pile of them as well as batteries. My only complaint (if you want to call it that) is, the Bauer battery recharging unit is slow to charge the batteries but that isn't an issue with me because I always have a number of battery packs charged up anyway. Nice thing about any Li-Ion battery pack is, they hold their charge for a long time, unlike the Ni-Cad packs that self discharge pretty quick.
Would I rely on the Bauer cordless tools for heavy use? No way, but for occasional use they are just fine in my scenario.
/ Echo 590 or the X Series? #65
Yes, it has the 20 inch bar.
I think the chain is too tight, but I left it like it was. There isn't any slack in it at all. I didn't know about the greaseable roller nose. I'll have to look into it. I didn't grease anything.
One thing that caught my attention was the smell of it while it was running. I was the same as an outboard motor out on the lake. It's hard to describe, but very recognizable. I've never smelled that with my other chainsaws, and I wonder if it's the canned fuel?
I never grease the tips on my saws. My oldest bar has distinctive enough wear that it probably needs thrown out but the tip is fine.
/ Echo 590 or the X Series? #66
Your choice but... If the bar has a grease hole in the end, you should use it. Kind of not changing the oil in your buggy sort of. People say that the bar oil will lubricate the sprocket nose, I don't see how that works in as much as the bar oil is outside of the sprocket nose and the centrifugal force of the spinning sprocket would throw out any oil that might get in there anyway. All my bars have grease holes and they get greased every time I use one (saw).
I've never worn out a bar, ever. If I get a burr on a bar rail, I'll file it off, not that I do because I don't get burrs on the rails. I always flip my bars over, every time I put on a sharp loop. I have worn out drive sprockets but those are easily replaceable and all drive sprockets today have maximum allowable wear indicators on them anyway.
/ Echo 590 or the X Series? #67
Canned fuel does have a distinctive smell unlike pump gas Eddie...
I always set my chain tension by tightening the chain and then lifting the end of the bar and observing how much slack there is then and then adjusting it tighter but only so tight as I can pull the lower chain run away from the bar and have it 'snap' back into the lower rail.
/ Echo 590 or the X Series? #68
If I was burning up tips all the time maybe I would do something different but I’ve literally never had one burn up. And a bar is like $50. If one did burn up it wouldn’t hardly be as big of a deal to burning up an engine from lack of changing oil.
/ Echo 590 or the X Series? #69
You prerogative entirely but a disposable (and actually refillable) grease gun with the required needle tip is less than 5 bucks so it's a cheap date today. I just happen to use a metal gun that I can refill and I use ultra buck high speed bearing grease but the disposa ones work as well.
...and I do know of some people who never change their oil as well.
/ Echo 590 or the X Series? #70
I grease mine just because it's there and only periodically. The angle drive on my weedeaters do get my regular attention. Lots of rpms at both locations.
/ Echo 590 or the X Series? #71
I bought the Echo CS-590 Saturday morning from Home Depot. I haven't been there on a Saturday in awhile, and it was really bad. Not enough people working there, too much junk in all the isles, and the chainsaws are all locked up. I waited my turn for the guy to come and unlock it, and take it to the cashier to hold for me. Seems like big crime has made it to Tyler Texas.
I bought a can of Husqvarna premixed fuel because I was walking down the isle in Lowes and saw it, so I bought it. It has an octane rating of 95. I didn't compare the other brands to see what their octane rating was, but I did look at the pump that sells Ethanol free gasoline. It's 91 octane. The Supreme which is on the same hose as the 87 and 89 octane fuel has Ethanol. If I buy the Ethanol free gas, which has it's own hose, it's a lot less octane then the canned stuff, but it's only $3.50 a gallon plus the oil, compared to $30 for the Husqvarna fuel. Is the higher octane rating noticeable or needed? I'm committed to never using fuel with Ethanol in this saw, I'm just not sure if $30 a gallon for gas is being smart or wasteful?
I've only used the saw for an hour to cut up some rounds. It started easy, it's a lot lighter then what I'm used to, and it has a bunch of power. I like that the fuel tank is semi transparent so I can see how much fuel is in there. I thought about the muffler modification, but I don't see the need to modify anything just the way it is. I'll know more by the end of the year, but my first impressions are very good. It was $419 that I'm happy with spending that amount of money.
Thank you for all your help and suggestions.
Congrats! I just got a 15% off coupon in the mail for Home Depot. I know I said I wouldn't buy a saw there, but the 15% makes it tempting.
/ Echo 590 or the X Series? #72
Many bars, mostly cheaper ones, don't have grease holes. Stihl also ditched grease holes on their Rollomatic ES bars, about 10 years back, which is exactly when and why I stopped buying Stihl ES bars.
Most good roller tip bars have grease holes, and this is the best way of cleaning swarf out of the bearing, as the grease pressure ejects dirt and fiber.
/ Echo 590 or the X Series? #73
I almost bought a 261 about 10 years ago and kick myself for not stepping up to that model, but aren't the Stihls now almost double the price of the Echos?
I paid abou 600 for my 261C with a 20” bar. Comparable Echos was maybe 1/4-1/3rd cheaper.
I have no problem with Echos and have owned a few.
/ Echo 590 or the X Series? #74
Just curious today retail list prices. I have never paid list on husky or echo saws before. Refuse to pay retail on stihl saws so I dont buy them new. Plus husky would even sell to me PHO. Echo too.
16 in. Stihl 261 $699.99 † DSRP
18 in. stihl 261 $709.99 † DSRP
20 in. stihl 261 $719.99 † DSRP
20" Husky 550xp mark II $699.99
20" Husky 545 MK II $639.99
20" Echo 4910 $379.99
20" Echo 501 $549.99
Stock for stock the husky 550 quickest strongest in cuts. But they got heavy like the 1st Gen older 261. So not as light and balanced like they used to be. But if you never owned first 550 545 saws you wouldnt know.
Newer 261's lost the weight and echo ones lighter even still.
My Gen1 ones from 10 years ago.
/ Echo 590 or the X Series? #75
I had a Stihl 250 and it made me a believer until the 2 Stihls were stolen from my shed. I replaced the 250 with the newest model 251. I hate that saw. It's been in the shop 2 times as I was tired of monkeying with it. Within a year I bought a Makita (Dolmar)for larger stuff. That's a good saw but i would probably buy an equivalent Echo if I get fed up and sell the Stihl.
/ Echo 590 or the X Series? #76
A more appropriate comparison for Echo would be the Stihl Farm Boss or the Husqvarna Rancher series. Of course Stihl and Husqvarna pro saws are going to be more expensive than Echo, what would you expect?
Here's a more useful comparison:
Stihl MS-250 Farm Boss: $399 MSRP
Husqvarna 455 Rancher: $599 MSRP
Aside from that, a 20" bar on a 45 or 50cc saw is somewhere between hopeful and stupid. Just because the oiler can support a 20" bar, doesn't mean the engine can actually pull it with the nose buried in hardwood under any reasonable pressure. Max bar length spec is a function only of what the oiler can support, not engine horsepower.
Cutting east coast hardwoods, you're going to be very disappointed trying to run a 20" bar on a 45 - 50cc saw. The guys cutting pine and fir in the PNW get away with that, but not us. Stick to 65cc or above, if you need to run a 20" bar with nose fully buried in oak or hickory.
/ Echo 590 or the X Series? #77
I didn't know about that either until about a year into chainsaw ownership with my Echo CS 490.
This is the greaser I use for the roller nose.
/ Echo 590 or the X Series? #78
If I was using my chainsaw a lot and knew I was going through a lot of fuel I would use the non-ethanol with premix oil. Once I stored it beyond a few weeks I would use the canned fuel.
Since I might use my chainsaw a few hours ever few months I use can fuel because when my chainsaw starts with no issues after sitting 2-3 months. $30/gal of canned fuel is ridiculous but it's the price I pay to know my chainsaw starts with no issue.
/ Echo 590 or the X Series? #79
Same greaser I use. Carry a $20 Victorinox Classic with the plastic toothpick, to clean out the grease hole before use.
You can buy refillable greasers for this, but at $7/ea and for as long as that little Oregon unit lasts (years!), I just throw away and buy a new one when I manage to run out.
Oh, and replacement toothpicks @ $0.92/ea:
/ Echo 590 or the X Series? #80
I will have to disagree. Both the farmboss and the rancher are clamshell cases and not easily split rebuildable unlike the Echo. I also find the Echo's to be better built than the cheap line of Stihl or Husky...
And I can run a 20" bar on my Husqvarna 550XP MKII all day in hardwoods without it skipping a beat. It's a beast of a saw! My Stihl 261 will also run a 20" blade as will my Echo 590. But typically when I need 20" I am using my Husqvarna 562XP and she's a screamer. a 50" saw isn't an ideal place for a 20" bar but some saws like the 550+XP doesn't bat an eye to it....
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2017 Isuzu NPR-HD 14ft. Stakebody Flatbed Truck (A64556)
2017 Isuzu NPR-HD...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
1995 Bulk 307 SS Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1995 Bulk 307 SS...
2022 EZ-GO ELITE...
