Do battery cables go bad?
/ Do battery cables go bad? #61
I know a company that makes thousand of crimps for fleet equipment. I have no doubt they will last the ten years that the equipment may be in service, but I don't think the crimps are up to OEM standards. OEM will get the perfect die. These guys will use the best they have to fit. Since it is a two piece die, you can see where it is sharp and deformed between the two dies. You don't see that on OEM.
/ Do battery cables go bad? #62
I should have saved the one I changed a couple weeks ago. Carrier transport refrigeration unit that had been looked at multiple times and had two starters thrown at it. Did a volt drop on the positive cable and it was losing 3.8 volts. Cable looked fine visually, no breaks in insulation, no damage at cable ends. Stripped insulation off and the cable inside had corrosion in multiple places throughout. Visual inspection only works on really evident problems. A volt drop test is the most accurate way to determine cable condition. Look for a max of .5 volts on positive and .3 volts on negative. Just because the cable has insulation covering it doesn't mean that it can't get moisture inside of it. There is always a bit of condensation that will form inside.
There you go. Voltage drop measurement is a great test, especially under load. As to why the wire fails internally as I mentioned it could easily be a manufacturing flaw. Domino effect also, a couple strands break, you can't see it from outside, but it's no longer the gauge wire it was.
A chain is only as strong as it's weakest link.
/ Do battery cables go bad? #63
At the rated load. In other words if the cable size was designed to pass 275 amps of starting current with maybe a .5 volt drop or less, then you have to assume the engineer did the math and the cable originally met that spec. When you attempt to apply the rated load that it was designed for and it drops too much voltage at that load, then by definition the cable is defective. I have seen so many that looked so good from the outside, and then you remove the jacket, and then the true nature of the degradation becomes apparent.
I have had similar experiences multiple times.
/ Do battery cables go bad? #64
I'm comfortable in saying with 99.9% certainty OP's problem isn't primarily with a cable. Two schools of thought have come forth,one holding out experience as the answer for electrical trouble,a second say's electrical problems can be solved using principals and theory. Beit headlamps,lack of ignition spark or blown fuses ,the same debate always take's place. One faction claiming to have seen xxxx to cause the exact problem and another saying get out your multimeter. If I were hiring an electrical troubleshooter,a 25 year old that can use a multimeter but only 1 year experience would get the job everytime over one with 30 years experience but can't realize full potential of a multimeter. Shortly after I came to this forum,a member suggested a thread dedicated strictly to basic electrical theory and use of multimeter. There was little response and 75% of it was against the idea. Non of that is suprising,,,,,,,,until,,,,,,,you consider how many weigh in on electrical discussions. If nothing else I say help's a single person,I promise you will never regret taking a semester of entry level dc circuits or brief apprentice with a knowledgeable individual. That will not make you an expert but you will not be asking questions like "voltage drop at what load"and best of all you will chase your tail far less often.
/ Do battery cables go bad? #65
yep....and there are the guys with 50 years of experience running service calls, and really really know how to use a multi-meter, or build one for that matter :)
/ Do battery cables go bad? #66
And there are others guys with 1/2 year of experience repeated 100 times.
Bruce
/ Do battery cables go bad? #67
Without a doubt but there's an equal number charging $80 an hour to work in shops that think Ohm's Law has something to do with prevention of cruelty to animals. Them boys you speak of can disassemble ECMs and fix them.
/ Do battery cables go bad? #68
Exactly. Pretty sure us old farts all mentioned voltage drop testing. I guess he thought we spit on our fingers..... I think I’m done here.
How do you load test a cable without the battery drop ruining the test?
/ Do battery cables go bad? #70
You take a reading at each end of the cable. Forget the voltage, you are only interested in the difference. It would be handy to have two meters calibrated the same and connected with clip leads. But again, taking good readings of this miserable 12 volt system in a dirty environment can be challenging.
I don't even like to bring my FLUKE stuff near some dirty old engine! lol
I agree 12 volts is stupid. I think there would be a lot less problems if it was 50 volts or higher. You hardly ever see problem caused by a loose connection in a 110 volt system.
/ Do battery cables go bad? #72
The battery doesn't have an effect on the test. I think there is some confusion on just how to perform a volt drop test. To perform a volt drop on a positive cable that goes from the positive post of the battery to the starter, you would set the multi meter to dc volts within the system voltage range if your meter has that option. Some are dc volts and you can set your decimal point with a range button, others have different voltage selections. Set your range for xx.xx volts. The meters with voltage selection usually have 20 volts as the lowest setting, use that one. Now pick one of your meter leads, doesn't matter which one, and hold it on the positive post of the battery, take the other lead and hold it on the other end of the cable at the starter. Crank over the engine preferably with ignition disabled to get a good consistent reading. What ever voltage the meter shows is how much voltage the cable has dropped. On a positive cable, .5 volts is the max you want to see. On a ground .3 volts is the max you want to see. You can even test connections the same way. One lead on the positive post itself, and the other lead on the terminal that is clamped to the positive post and crank over. This will let you know if there is corrosion within the clamp. With a meter set on voltage, it measures difference in potential between the two leads.
/ Do battery cables go bad? #74
No! It's a VALID point. 24 volts would have been so much better. Just look at the crappy performance of 3 volt flash lights over the years, shaking them to get going, just to get some contact. Higher voltages ARC and virtually weld their connections.
A starter motor armature would see so much less current and heat as well.
Q
Until the building burns.
What happens when a massive amperage 12 volt cable frays and shorts out against the the frame?
And you could use a lot smaller battery cables and boosting would be easier when the time comes.
/ Do battery cables go bad? #77
Your dump truck is a chevy right?
Alot of them "back in the day" wouldn't start well when hot.
A heat shield on the solenoid will fix that problem.
/ Do battery cables go bad? #78
Theres about a million different ways to do it. Fixed more than one car that way.
Some guys put a ford solenoid up on the fender. I haven't done that.
The poor little solenoid doesn't like living next to the exhaust manifold. On a hot soak (sitting after running a while) things "soak up" the heat and are hot all the way through.
/ Do battery cables go bad? #79
Just read first post. Dont know if diesels had the problem. I was thinking sbc/bbc. Its still a possibility.
Get new cables that are made for the truck. No universal crap.
/ Do battery cables go bad? #80
I thought Ohm's law described why armadillos were coming up from N. Texas into Kansas.
Ford F800 (A63689)
Ford F800 (A63689)
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2019 John Deere 4044M (A62177)
2019 John Deere...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
