Do battery cables go bad?
/ Do battery cables go bad? #21
When you only have 13.8 volts to start with, taking voltage drop measurements becomes difficult. Just jabbing your probe a little harder, already gives you different readings!
I have worked on thousands of electrical/electronic problems. Many thousands! But the 12 volt starting circuits are the worst! A bad battery can destroy your starter motor. So you replace your bad battery thinking everything is OK and yet you still have problems. Usually just a bit later, just to mess with your head. I was stuck a whole night at the side of an Interstate in the early 80s because of this!
/ Do battery cables go bad? #22
I had the cable go bad on my Yanmar. It started fine at the shop but refused to do anything a few minutes later. Cables looked fine, no corrosion. I removed the starter, took to the shop and tested it, it worked fine. Put it back on, nothing. I removed the cables, cleaned up every thing even though nothing was corroded. While replacing the battery clamps to the battery, I discovered the problem. I had to tug a bit on one cable to get it on the battery and the clamp came off in my hand. It had corroded inside the crimp of the post cable clamp and was just powder inside the crimp. I replaced the cable and no more problem. It was hard to believe that absolutely nothing was visibly wrong with it.
/ Do battery cables go bad? #23
I always solder the ends when making heavy cables. Trouble is, the solder wicks up the cable a bit making them hard and ugly. Better that, than a connection issue later though.
/ Do battery cables go bad? #24
If you suspect a cable with a high resistance, then a simple voltage test of the cable will prove it one way or another.
Take your digital voltmeter and place one probe on one terminal and one probe on the other end. Attempt to start the vehicle, so as to draw a large amount of current. If you read much over .1 volts difference in potential end to end, and of course the higher the voltage you read the worse off the cable is. It has a high resistance.
Think of it this way in the extreme. If the cable/wire had zero ohms of resistance there would be no voltage difference end to end because the wire is "perfect" and has no resistance to current. Of course no wire is "perfect" and actually has zero ohms of resistance, but a bit ole starter cable certainly has low, near zero ohms of resistance. Of course a resistor will show a difference in voltage from one end to another as the load tries to draw current from the battery. A defective corroded battery cable is a resistor and resists the flow of current.
Without drawing a load current thru the wire, there will not be a voltage difference so doing a static voltage test will not show you anything. If you replace the starter cable with a 1000 ohm resistor you would still measure the 12 volts on both ends with a simple static voltage test.
/ Do battery cables go bad? #25
YES,,, Not really go bad, but the terminal and the wire contact can become insufficient enough for problems.
You can just cut the bad end off and get a wire clamp terminal to replace it, if the wire is long enough.
Replacement cable ends have a tendency to corrode where they clamp on to the wire.
You can't always see this corrosion, until you take it apart and inspect it.
I have been repairing vehicles for decades, and I have seen many vehicles towed because of those clamp on ends.
They have caused breakdowns, with batteries and starters being replaced damaged, or unnecessarily replaced, before someone realizes the actual problem is that connection.
The replacements ends are fine for a short term temporary repair. But, battery cables are not that expensive. Do it right, and replace the whole thing. You may save yourself a lot of trouble later.
/ Do battery cables go bad? #26
This has to be the poorest solution for rapair of battery cables....
IF you suspect bad cable just replace it....At least it removes it from hard start equation....
I have had batteries in vehicles up to 8 years with out any problems with corrosion at clamps or cables, I borrow knowledge for the industry I uses to work in.... We use NO-OX-IDE compound (grease) to coat thoroughly cleaned battery posts and cable clamps to prevent corrosion.... I do not have battery terminal corrosion problems, EVER... Battery usual just die from old age for me ...
If it takes several "clicks" of ignition switch to start vehicle I usually suspect the high amperage contacts in solenoid as being issue, they fail because the constant arcing of high current (amperage) causes burned or carbon coated contact inside solenoid....
Dale
/ Do battery cables go bad? #27
Battery has acid, corrosive fumes, attacking the copper and internal corrosion. Seen parking brake and shifter cables weld internally while working in repair industy and even one myself because that was path of least resistance for current to flow. I had a honda civic in about 1990 and the bearing on the input shaft fried/welded due to poor ground. Could see the electrolysis marks on ring gear teeth. I imagine it looked like sparks around brushes on a electric motor while cranking. I try to run a ground to starter brace, bolt or bellhousing on everything.
/ Do battery cables go bad? #28
Dale
I have been telling people that for the better part of 40 years now. If you use NO-Ox-Id, you will never have a battery cable problem or connection terminal problem. It is also good for sheet metal screws in automotive used, like mounting radio equipment in vehicles where the screws are exposed to the elements (thru transmission hump, and antenna brackets etc). But a lot of people don't believe me. It is their loss. I have treated every battery/terminal/connectin in every vehicle I have owned .
It amazes me, that such a simple inexpensive solution for no start problems exist, yet very few know about it, and those that do, don't believe it.
/ Do battery cables go bad? #29
By the way what industry did you work in to use NO-Ox-Id. I found out about it when it was sent with every PBX battery plant I ever installed. I worked in Telecom for decades.
/ Do battery cables go bad? #30
petroleum jelly also works to coat exposed surface and I found that in a Model T Ford book...
I've had very good luck with the treated felt pads... some will say it is a waste of a dollar...
/ Do battery cables go bad? #31
I've been using petroleum jelly on all these battery, starter and ground connections (including clamp-on ends) for almost 50 years now and have never had a problem.
/ Do battery cables go bad? #32
Next time it won't start try jumping the cables with jumper cables, both on the hot side and the ground side.
/ Do battery cables go bad? #33
Telcom for 38 years, first it was "Western Electric" which became "AT&T Network Systems" and later "Lucent Technologies"...
Dale
/ Do battery cables go bad? #34
Another good solution at auto parts and such is "dielectric grease", use it on all crimp terminals and on batteries even dry cell flash lights and electrical such as light bulbs in auto and house.... The secret to using dielectric grease is having solid, clean mechanical connection under the grease.... What the grease does is keeps oxygen and moisture out of connection so it does not corrode..
Dale
/ Do battery cables go bad? #35
I jumped a truck with 12 gauge wire once. I have 2 pair of vice grips so I clamped 2 ends. I just twisted the other 2 ends. I waited about 15 minuets and it fired right up. So really I just charged the battery. You don稚 need huge heavy gauge jumper cables as long as you have a battery that will take a charge and youæ±*e patient.
Did the same with a wire coat hanger once.
/ Do battery cables go bad? #36
Dale
Exactly what I use.
/ Do battery cables go bad? #37
Dale
Well, there you go. Sounds like we have been down some of the same roads.
/ Do battery cables go bad? #38
that's odd,, any cable can cause the problems you described it's what this thread is about LOL!
Clamp terminals have been around a long time decades even! It's a fix that can be done easily, are they perfect?,, nothing is!!
incase you haven't noticed.
/ Do battery cables go bad? #39
Copper multi strand wound cable does fail for various reasons. Ask anyone who has a motorboat and uses it in salt water.
Additionally, wire dries out and basically dry rots over long periods of time, like the 30 years or so the OP's truck has racked up. The current passing through the cables over years wears on them as they heat and cool, expand and contract, in cold and hot weather too. Wire just wears out over time, even without the ravaging effects of corrosion from atmospheric conditions, salt water, humidity, oxidation, loose clamps, etc. High resistance from worn or barely contacting starter parts, bad brushes, worn bushings, loose ignition wires, and on and on.
Most problems occur at the ends of the wire at the frame for grounds or at the battery with worn or poorly clamped or crimped connections.
Certainly No-Ox is good and so is the dielectric or Vaseline or most any high quality grease that will coat and keep oxidation from occurring.
Personally I like to use the felt washers in combination with bright clean posts and bolts at frame connections in conjunction with battery terminal spray to completely coat and seal air out.
Once completely sealed corrosion is next to impossible to haunt one's battery cables.
I think the OP may find his cables in addition to his flywheel need to be thoroughly checked out. Why did you, OP, replace your starter? Was it worn out/dead?
I think the hot restart may be connected to higher resistance when hot. (Possible cable issues). As far as cold starting the starter/flywheel condition/teeth of Bendix and flywheel meshing without improper alignment may be a second issue(s).
I replaced the starter because I thought it would fix this issue. In hindsight it didn’t. It does turn faster and did fix the taking a bunch of turns to start issue.
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
213085 (A64276)
213085 (A64276)
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2016 Cadillac XTS Sedan (A64557)
2016 Cadillac XTS...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
