Tractor hard to start in cold
/ Tractor hard to start in cold #21
Hi,
I’ve done research but have not found a solution. 1998 John Deere 310SE backhoe with 4.5l (272ci) diesel engine. When mild temps , starts immediately. When cold, will hardly turn over and sometimes not start. Put battery charger on it and it shows batteries almost fully charged. Three guesses as to what might be going on: bad ground wiring; bad starter motor; or batteries (2). I just can’t think of why it starts like a champ all summer, then barely turns over when cold (below 35f). What would be most likely affected by cold temperatures? Seems batteries to me, but curios if anyone has had and cured this problem. Thanks.
I’ve got my dad’s old 1973 820, and he installed a lower radiator hose heater when he bought it new. I plug it in 1/2 hr before using it and she fires right up. Even at zero or below temps.
/ Tractor hard to start in cold #22
Guys,
Thanks for the replies.
Batteries have not been load tested. I’ll remove them and clean all wiring as suggested. While out I’ll have them load tested.
No glow plugs. Strange. Instead, has an ether-shot system. Ether can sits in holder hear engine; hit a button for the shot while starting. I’m Leary about using ether, but since this is a factory set-up, JD must have thought it ok.
Plug in heater is on machine, but often times the need is unanticipated. Will have to think about use and plug in when needed.
Not sure about engine oil or hydraulic fluid viscosity. Has clear hydraulic fluid when shop R&R’d a leaking swing cylinder. Have heard bad and neutral about clear fluid. Still has leak near swing cylinders, and plan to change fluid to better when I do the work on leak this time.
If it turns out to be the batteries, is it possible to install one to get the job done, or stick with the two? ($$). 4 cylinder diesel shouldn’t take much juice, but if it’s fighting hydraulics on start I can see the need for two.
Many thanks for the tips.
"Plug in heater is on machine, but often times the need is unanticipated." Might want to consider a timer; having the heater come on for a short period even when tractor not used won't hurt, other than the low cost of the electricity used over the short period.
/ Tractor hard to start in cold #23
I have a JLG 40 H boom lift that was always slow cranking even with a new battery. I would have to put a battery booster on it in order to get it to start. One day I was in harbor freight and saw an amp wiring kit 2 6ft long 00 wires . Replaced the cables and it’s like a new machine . 1993 ford industrial gas motor but the long cable runs were the problem .
/ Tractor hard to start in cold #24
Diesels are compression ignition engines: they rely on the heat generated from the compression as the cylinder moves to ignite the fuel. The heat that fuel sees is proportion to the speed of the compression. So while a gas engine might start with slow cranking (since the spark plug still fires), a diesel engine is more directly affected. Possible causes of slow cranking:
  1. Weak battery/batteries
  2. poor electrical connections in the battery to starter circuit
  3. Wrong viscosity engine oil (and/or hydraulic oil, on some tractors)
  4. Starter going bad
  5. Some diesel engine designs just don't handle cold starts as well. You may have to resign yourself to preheating in cold weather.
Of these, I would start by examining the batteries and electrical connections. It's easy and inexpensive to check. Also, your statement "Put battery charger on it and it shows batteries almost fully charged" could indicate a problem: a battery that has been on a charger for an appropriate length of time should show full, not "almost full".
Some steps to check the battery:
If your battery is the flooded lead-acid type with removable caps on the caps, open the caps and fill to the appropriate level with DISTILLED water. (Many flooded lead-acid batteries have a sort of "split ring" inside or other indicator: you fill up to that point.)
Charge the battery, let it rest for a few hours and measure voltage. For a 12V flooded lead-acid battery it should measure right around 12.7 volts. If you let it sit overnight, it should still measure close to that voltage the next day (a significant drop in voltage indicates either a parasitic draw on the battery, or internal battery problems). Use a known accurate voltmeter for these tests (The Harbor Freight $6-7 voltmeters are good for rough indications, or indicating that this battery is showing the same it was yesterday, but I've found that they vary from one unit to another, sometimes by as much as 0.5 volts.) If you are concerne dthat your tractor may have some phantom loads, which are discharging the battery when not in use, you may want to try this test with the battery disconnected.
Measure voltage while cranking the engine. If it drops way down (like 10.x volts on a 12 volt battery) that's an indication of a problem: it could be in the battery or the connections.
A battery that drops to +/- 11 volts or so just while resting for a few days likely has a shorted cell. That battery is probably junk.
Letting a battery sit in a discharged or partially discharged state for an extended time causes sulfation in the battery, lowering battery output and shortening it's life. Heavy sulfation can sometimes mimic the symptoms of a bad cell. A You can try putting a charger/maintainer on the battery that has a desulfation feature. I've had luck recovering some moderately sulfated batteries with this. Note that if the battery has significant sulfation, it can take a week or more of desulfating it to really make headway in recovering it, if it can be recovered at all.
If you have a two battery system, you should always replace the batteries at the same time. This is true whether your batteries are connected in parallel (still a 12V system) or in series (creating a 24V electrical system).
Electrical Connections:
Poor electrical connections can cause your batteries not to charge fully from the tractor's charging system. Chronic undercharging causes sulfation (as mentioned above) and shortens the life of the battery.
Clean the top of the battery: sometimes the accumulation of acids, oils, dirt, etc forms a conductive path between the posts, causing a slow drain on the battery even when not in use. Even just wiping it clean with a rag or paper towel can help. I sometimes wipe it down with a mix of baking soda and water, which neutralizes any acids which may have collected on the top of the battery (sometimes the battery will outgas acid fumes when charging). If you see things fizzing while doing this, that's an indication you had residual acid on the top of the battery. NOTE: be VERY careful not to get any of the baking soda and water into the battery cells.
As others have already mentioned: Clean the connections at the batteries and at the grounds. Check where the negative cable on a negative ground tractor attaches to the frame, and look for other areas where electrical connections are attached to the frame. Also look at the positive connections. Pay special attention to connections at the batteries, starter, and alternator or generator. After going through the connections, charge the battery and try the tests mentioned above to see if things have changed.
Hydraulic and engine oil viscosity:
One of the first things I do when buying used equipment is change all the fluids and filters. You never know what the previous owner used or whether they actually replaced them at appropriate intervals. (In RARE cases, I'll make an exception to replacing fluids if I know the previous owner personally, and know they are the type to take meticulous care of their equipment.) Find out what viscosity is recommended for your make/model tractor in the temperatures you expect to see in your area. If your tractor is old enough that it recommends single viscosity oils, consider substituting a modern multi-viscosity oil to cover the temperature range you expect to see.
Starter issues:
I went through all the steps I could think of when I had trouble starting my 20+ year old tractor a couple of years ago. It had first developed issues starting in colder weather. My block heater had died, but the hard starting was happening even in temperatures where I had not needed to preheat in the past. For a time, I could overcome this by cycling the glow plugs a couple of times before starting. Eventually, the temperature at which it would start crept up to the poitn where I was having to crank the engine for significantly longer, and sometimes multiple glow plug scycles still resulted in difficult starting. I was stumped, so I brought it in for service. They found that the starter was going bad and cranking too slowly. The engine wasn't generating enough heat at the slower cranking speed to ignite the fuel (not an issue in warmer weather, and that's why the multiple glow plug cycles sometimes helped). They replaced the starter, and it's been starting easily ever since. The starter had deteriorated gradually enough that I had not really noticed the difference in cranking speed. I could certainly tell the differenc ewhen they replaced it.
/ Tractor hard to start in cold #25
My John Deere 2020 diesel is the same way. If the temperature is below about 50 degrees it struggles to start. I installed a coolant heater on it many years ago; I plug it in a half hour before using and then the tractor starts just fine. Something like this only mine is probably 30 years old:
That link does not work for me. It triggers a 404 error Message ("Page Not Found"). However, this one does work for me.
/ Tractor hard to start in cold #26
Maybe check the viscosity of the motor oil??
/ Tractor hard to start in cold #27
[....] "Measure voltage while cranking the engine. If it drops way down (like 10.x volts on a 12 volt battery) that's an indication of a problem: it could be in the battery or the connections." [....]
The above is an extract of a very good and comprehensive post by John_Mc. (Not me.)
The one thing that I would add is that, if one gets a low-voltage reading while cranking the engine, the significance of that reading depends upon exactly where one is taking the reading.
If the battery is well-charged, and if the probes of the voltmeter are held directly against the battery's terminals, and if the voltage sags unduly when the battery is placed under load, then that voltage sag indicates that the battery probably needs replacement.
On the other hand, if the voltmeter's positive probe is held against the positive terminal on the starter's solenoid, and if the negative probe is held against some point on the chassis of the tractor, and if the measured voltage sags when the tractor is cranked, then the cause may be resistance between one or the other (or both) of the battery's terminals and the cable(s) to which that terminal is (those terminals are) attached, or the cause may be resistance between the positive cable and the terminal to which it is attached, or the cause may be resistance between casing of the starter and the chassis (or resistance inside the solenoid or the starter), or the cause may be resistance between the negative terminal of the battery and the chassis.
The battery, the cables, the starter solenoid, and the starter together form an electrical circuit... an electrical loop. The sum of the voltage drops all of the way around the loop must equal zero. This is Kirchhoff's Second Law (also known as Kirchhoff's Loop Law or Kirchhoff's Voltage Law).
So, if the battery, when cranking, develops 12 volts (measured directly across its terminals), and only 10 volts appears between the positive terminal of the solenoid and the casing of the starter (or the chassis), then those other 2 volts are due to resistance or resistances somewhere in the loop.
One can use a voltmeter to measure the voltage drop across each element of the circuit (of the loop). The voltage drop across each element of the circuit will be directly proportional to the amount of resistance that that element presents when the battery is under load... that is, when the operator tries to crank the engine.
For best performance of the starter, one wants to keep the resistances as low as possible, so that the starter sees as much as possible of the voltage that the battery generates, and so that the starter receives as large a current from the battery as possible. If they are high enough, resistances in the circuit, e.g., due to corrosion between the battery terminals and the battery cables, deprive the starter of voltage and can starve the starter of the current that the starter needs to vigorously crank the engine.
/ Tractor hard to start in cold #28
if using 15w-40 try 5w-40 as suggested, you should notice a difference with cold weather starting, also batteries make a huge difference
/ Tractor hard to start in cold #29
The use of the words turn over are often misused. Do you mean that it turns over but slowly? Or does turn over at about the same speed as it does when it’s warmer but not start? We need to know if it is electrical or other issues. From the electrical standpoint you have to follow up with the information given above and you should have a minimum of 9.6 volts at the starter when cranking. Load testing batteries today is kinda old hat. The modern thing is a conductance type tester like Midtronics.
/ Tractor hard to start in cold #30
Hi,
I have a 510 and when it needed new batteries I just bought one large 12v. It was cheaper then 2 six volts and dropped right in. I do not know if the 310 has the same battery compartment, you will have to measure to see if one will fit and if it has the same cold cranking amps.
/ Tractor hard to start in cold #31
LHF,
I’m up on maintenance on the six tractors I run in the farm. The 310SE is a newer purchase from someone who had done a recent maintenance and so I didn’t see the need to change fluids right away. Levels are good, but do plan to change oil and filters soon to have a baseline. Thanks for the heads up though.
Until Jim had mentioned the destroking solenoid I was leaning toward battery issue. Still the most likely culprit and will verify when chores slow down. Good to know about that solenoid.
Will do as LHF suggests and do electrical first so we figure out what it is or isn’t one step at a time. Many thanks.
Best regards.
I didn’t see this mentioned so, after you cleanup the connections use a dielectric grease to prevent/slow corrosion. It is worth the extra couple bucks. I’d also get the batteries load tested and find out CCA. My guess is they aren’t rated for much in low temps or they’re at the end of their useful life.
/ Tractor hard to start in cold #32
For what it is worth - - - - and not knowing your circumstances, budget, etc. - - -
Given the current cost of batteries, I'd recommend battery maintainers.
(And, no, I have no connection to the battery or maintainer businesses.)
It sounds like you may not use this equipment frequently. If you have the time to try it, you might put a battery maintainer on each battery for a couple of weeks and give it a try.
I was skeptical at first, but I've become converted. I've got maintainers on 6 pieces of equipment now. A couple of the batteries are in the 10-year range and still seem to be functioning well - - - knock on wood. I think this is particularly important for equipment that doesn't get used frequently, as the batteries slowly discharge and get sulphated, especially in winter.
I'm sure there are a lot of varied preferences out there, but I now use the NOCO Genius 1A. About $30 at Amazon. Inexpensive compared to a new battery and/or the inconvenience of equipment that doesn't want to start when you need it.
The maintainers typically don't like to work on a fully discharged battery, but even the low amperage (inexpensive) models will eventually top up a partially discharged battery if you give then enough time. And the de-sulphating mode may only kick in after the battery is fully charged. And the de-sulphating process may take a while.
So, without knowing more of your situation, I'd offer this.
1.) Disconnect both batteries and load test them individually.
2.) If they are good or 'marginal', check out the wiring, connections, starter motor, lubricants, etc.
3.) If they are sub-marginal or bad, you should probably replace both of them.
4.) Or, if they are marginal or even sub-marginal and you have the time available, you could try to resurrect them by fully charging them (individually) and them putting them on maintainers for a couple/few weeks. The cost of the maintainers is less than the cost of a new battery.
5.) Even if you replace the batteries, you might want to keep the old batteries and try to resurrect them with maintainers. You might actually end up with a couple of decent spare batteries.
NOTE: As someone else mentioned, you should probably avoid mixing old and new batteries in a system. An old/marginal battery will act like a parasite, always drawing down the new battery and degrading it more quickly.
Hang in there.
/ Tractor hard to start in cold #33
Glow plugs?
The 310, 410, 510 TLB series do NOT have glow plugs or intake heaters. The batteries are two each large commercial 12v in parallel, not two 6v in series. So many of the replies in this thread are general to starting any diesel in colder weather. But the basics on a particular model must be considered or the OP is sent on a rabbit trail.
One question that I would ask is how many hours are on this unit? Since it has no intake or glow plugs for preheat it really needs its compression at its best possible for cold starts. As designed it SHOULD start just fine in cold weather with the correct weight engine oil for the season and the batteries/cabling/starter in good order. As for hydraulic drag it doesn't use UTF and who is gonna change out 20-25g anyway?
I've had a 410j for 14 years and even down to multi-day single digits with straight #2 and antigel it fires off immediately and isn't even that noisy/smoky when it does start. It's a good and reliable engine with mechanical injection. Yes, it does crank a bit slower when it's a really chilly cold start. It doesn't have a block heater and is never close enough to an outlet anyway. But if all the basics are in order and the unit has a bunch of hours a block heater for a few hours would be an easy way to make sure it can fire off when needed in cold weather.
/ Tractor hard to start in cold #34
Hi,
Load test batteries...they can show voltage but be sulfated and have low amperage. I see that all the time. Remove flow plugs...12 volt negative to body, positive to connection threads. Rip about glow cherry red very quickly. If one bad, replace all They don't last forever.
/ Tractor hard to start in cold #35
I use this to check my batteries:
Harbor Freight $19.99 Wally world $27
willy
/ Tractor hard to start in cold #36
Have you tried jumping it to assist the batteries? Good jumper cables run from a running engine should give all the voltage needed to boost a start.
/ Tractor hard to start in cold #37
Unless you make your own cables from welding lead good luck finding decent or good cables.
/ Tractor hard to start in cold #38
Lower viscosity oil in the winter may help. Check your manual and see what is required for colder temps. Do both batteries. If the are wired together the weaker one will fight the stronger one. I remember having a diesel pick up dual batteries. They always said to change both at the same time so they would be the same strength
/ Tractor hard to start in cold #39
Just to add another worthless post to this thread/
My Fordson (gasoline) won't start well in cold weather unless......
The PTO is disengaged, the lift pump drive is thrown out, and the wet clutch is pressed.
Then the engine spins without drag, the magneto spins to make a good spark , and the old gal lights right off even at 10 degrees of frost.
/ Tractor hard to start in cold #40
Agreed I use #2 CU to make mine using Anderson connectors to create a "modular" system using connectors mounted on my truck and tractors.
Not sure the OP is still around, but my other thought was to disconnect one battery and than the other to see if the engine turns over at the same speed on one battery. Could be just one failed battery drawing the other down.
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2010 CHEVROLET SILVERADO 2500HD (A65643)
2010 CHEVROLET...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2017 Kubota L3901 (A64126)
2017 Kubota L3901...
211299 (A62131)
211299 (A62131)
