DIY bucket level indicator
/ DIY bucket level indicator #1
ruko
Stacy, MN
None
I need a level indicator for my bucket attached pallet forks. I need to know if the forks are level in any position the forks are relative to the ground.
/ DIY bucket level indicator #3
Unless you have self leveling option on FEL it probably not going to happen.... Usually rudimentary bucket level indicators only work when bucket/forks are on ground level....
A quick search will probably show up about 20 different bucket/fork level indicators from simple to real complex...
/ DIY bucket level indicator #6
A remote tilt sensor (inclinimete) with a remote display would work. Some are self contained and can connect to your phone via bluetooth and use that as the display. Another one of those things the price is as high as you want. I would expect something tiny like for a drone would do the job and be reasonable. Or you can get them with dedicated displays and wired to vehicle power.
Ebay, Amazon, AliExpress will have them.
/ DIY bucket level indicator #7
My LS came from the factory equipped with a bucket level indicator rod somewhat similar to the one in Jeepheads video, I definitely appreciate having it !
One of my Kubota friends operated my tractor for a couple hours and said he was going to make one for his Kubota that came without one.
/ DIY bucket level indicator #9
I unplugged my seat switch, so I can stand up and see the fork tips as I load something. I can also stand next to the right side of the tractor and move the tractor and/or loader as needed.
/ DIY bucket level indicator #10
Take a 2" long piece of angle iron (2" X 2") and put the forks level on the ground. Now, find a place you can see the mount from your seat. Weld that iron on the mount so that one side is flat and level. Then just look at that any time you need to see what the forks are doing. (I'm sorry, but I don't think I'm describing it well here.) here is a photo of a factory one...
/ DIY bucket level indicator #11
Only works when the bucket is on the ground. My Yanmar YT359C has a nice bar that does the same.
My John Deere 310SE backhoe has auto level. When you float the joystick to rotate the bucket down, it automatically stops at level. But level for the ground.
In addition it also controls the bucket when you raise a load high, keeping you from pulling back too far so you don't dump on yourself.
Recently sold that machine.
/ DIY bucket level indicator #12
The problem with these types of indicators is that they only give you the correct tilt for a given loader height. Mine came with this type of indicator from the factory and I calibrated it to show “leve” when the FEL is at ground level. Raise or lower the FEL by even a little and it’s no longer accurate.
That being said, watching the video I realized that all that’s needed is a bottom heavy indicator loosely bolted to the side of the forks plate (if you can imagine what I mean).
/ DIY bucket level indicator #13
I just realized that the solution for an accurate indicator is as simple as drilling a hole on the side and loosely bolting a bottom heavy thin piece of flat stock. This type of indicator is not dependent on the height of the FEL like the regular rod indicators are. This is so simple that I’m thinking that maybe I’m missing something.
Here’s a quick finger sketch for my phone:
/ DIY bucket level indicator #14
Great idea except wont it always read level?
/ DIY bucket level indicator #15
Better-than-nothing: a level indicator for level ground that's only accurate when the bucket is at ground level.
Pretty-good: as above that also works at any bucket height.
People-in-hell-want-ice water: bucket parallel indicator. Keeps bucket parallel with sloped ground when you're working up or down hill. (So, no plumb based mechanisms)
/ DIY bucket level indicator #16
I’m assuming it’ll always read level but, sometimes the item you’re trying to lift isn’t on level ground. I guess in those cases it wouldn’t be as accurate.
/ DIY bucket level indicator #19
There is an RV electronic level indicator sold by Amazon and Walmart.
LevelMatePRO Wireless RV Leveling System​
Should work fine mounted on the side of the bucket and protected somehow.
/ DIY bucket level indicator #20
Got inspiration from this thread and built a prototype. Sorry for a bad picture.
So far works very well, no mater how high the forks are, it always show when they are parallel to the ground.
I'll give it a try for a while and see if it is useful i'll build something better.
2009 Featherlite Race Car Hauler Enclosed Trailer (A62613)
2009 Featherlite...
37 Gallon Aluminum Auxiliary Tank (A64127)
37 Gallon Aluminum...
Box Blade (A62613)
Box Blade (A62613)
2009 International 4300 Box Truck 24' (A62613)
2009 International...
Merritt Headache Rack (A64127)
Merritt Headache...
Rotomec Auger (A64127)
