Diverter to 3rd function
/ Diverter to 3rd function #41
What is the model number of your loader?
/ Diverter to 3rd function #43
Now we know.
I just found out that that particular valve does not have a PB adapter.
The port for the pump flow is the green port and feeds the hyd block and then goes back for the remotes and 3pt.
I will have the schematics for the loader valve shortly.
So you should have no problems adding another valve in series.
This is the first loader valve that that I have come across that has a dedicated port for PB without a PB adapter.
http://web.mail.comcast.net/service/home/~/Document.pdf?auth=co&loc=en_US&id=277543&part=2&disp=a
Found this valve on Ebay.
Looks like your valve.
Kubota Joystick Valve Part M1822 | eBay
Do you know how to install the 3rd function valve now?
If not holler back.
Think so. That is the valve.
Other projects and expenses coming up. It will be a few weeks before i get time to do that. AND suppose to get hotter than blazes about the time i can do it. This old man doesn't like working in the heat .
So.... I'll post results once done.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
DEUTZ MARATHON...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
