Diverter to 3rd function
/ Diverter to 3rd function #41
What is the model number of your loader?
/ Diverter to 3rd function #43
Now we know.
I just found out that that particular valve does not have a PB adapter.
The port for the pump flow is the green port and feeds the hyd block and then goes back for the remotes and 3pt.
I will have the schematics for the loader valve shortly.
So you should have no problems adding another valve in series.
This is the first loader valve that that I have come across that has a dedicated port for PB without a PB adapter.
http://web.mail.comcast.net/service/home/~/Document.pdf?auth=co&loc=en_US&id=277543&part=2&disp=a
Found this valve on Ebay.
Looks like your valve.
Kubota Joystick Valve Part M1822 | eBay
Do you know how to install the 3rd function valve now?
If not holler back.
Think so. That is the valve.
Other projects and expenses coming up. It will be a few weeks before i get time to do that. AND suppose to get hotter than blazes about the time i can do it. This old man doesn't like working in the heat .
So.... I'll post results once done.
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
TAKEUCHI TL6R SKID STEER (A65053)
TAKEUCHI TL6R SKID...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
