Diverter to 3rd function
/ Diverter to 3rd function #41
What is the model number of your loader?
/ Diverter to 3rd function #43
Now we know.
I just found out that that particular valve does not have a PB adapter.
The port for the pump flow is the green port and feeds the hyd block and then goes back for the remotes and 3pt.
I will have the schematics for the loader valve shortly.
So you should have no problems adding another valve in series.
This is the first loader valve that that I have come across that has a dedicated port for PB without a PB adapter.
http://web.mail.comcast.net/service/home/~/Document.pdf?auth=co&loc=en_US&id=277543&part=2&disp=a
Found this valve on Ebay.
Looks like your valve.
Kubota Joystick Valve Part M1822 | eBay
Do you know how to install the 3rd function valve now?
If not holler back.
Think so. That is the valve.
Other projects and expenses coming up. It will be a few weeks before i get time to do that. AND suppose to get hotter than blazes about the time i can do it. This old man doesn't like working in the heat .
So.... I'll post results once done.
Caterpillar 3208 Power Unit (A64127)
Caterpillar 3208...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2015 Deere 210G (A64126)
2015 Deere 210G...
KUHN FC2860 TLD 8' MOWER CONDITIONER (A64277)
KUHN FC2860 TLD 8'...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
