Diverter Valve Troubles
/ Diverter Valve Troubles #1
xanadu1797
Kubota B26
Have installed on my Kubota B26 a Surplus Center 6gpm Dual Solenoid diverter valve to serve at the front auxiliary hydraulics to power a grapple. So I've found that the grapple will work with the AG hoses hooked together in one configuration but not the other. When I switch to the non working configuration the grapple will close but not open. When I switch the quick couplers the grapple works fine but I have chatter on the curl circuit (plumbed to the surplus center block).
Oh, when I switch the Feed and Return lines to the Aux lines at the block, the same thing happens so I think that rules out the quick attach connecters up front.
I'm guessing this is a problem with the spool valves somehow but I can't get any farther. Thoughts?
/ Diverter Valve Troubles #2
Do you have a diagram or schematic for diverter valve? If nothing else maybe a couple pictures of the valve would help.
/ Diverter Valve Troubles #4
Old thread, but still good info:
Here’s a schematic for the diverter
Anything I can do to fix this?
For example- plumbing the diverter to the loader boom cylinders
/ Diverter Valve Troubles #7
I would confirm that your loader valve has regen feature before changing anything. First would try pushing joystick farther to right while dumping to see if moves similar to putting lower into float. If yes hold joystick there and try operating the diverter. Note: it will move quickly but test is to verify it functions.
If yes then you have have confirmed regen feature on your loader valve.
Depending on how your grapple is made it might operate in an acceptable fashion by plumbing it so that the cylinders retract when using curl and extend when in dump mode. This would also potentially point towards having regen on dump circuit..
/ Diverter Valve Troubles #8
If you indeed have a 3-way valve, then yes, moving the diverter to the lift/lower circuit will solve the issue.
Yep, that's the fix. Thanks a lot you guys! The grapple has waaaay more power now. The chattering is also gone.
On to the next thing while I have you guys here.
Since I installed front and rear diverter valves I've notices a slight drip from the backhoe spool valve. The fluid appears to be seeping out the bottom of the spool valve. I had the valve rebuilt just a year ago. Is this a likely premature failure from some pressure inbalance caused by the diverter valve powering the thumb?
Thanks again
Last time I had trouble with the spool valves and took them to be rebuilt they leaked from the top where the valves are visible. Any suggestions as to why they are leaking through the bottom?
There appears to be a plate or cover which is fastened onto the bottom. Don’t know if that holds any pressure but there is a gasket between it and the valve body. I think this is where the drip is coming from
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2020 DRAGON ESP...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
1995 John Deere 7400 (A60462)
1995 John Deere...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
