3-Point Hitch Converting cat 1 to cat 2....box grader
   / Converting cat 1 to cat 2....box grader #1
inode
Tennessee
Kubota M7060HD12
Can I set this cat 1 box grader up to work with a cat 2 quick hitch? I’ll be using it with my Kubota M7060.
   / Converting cat 1 to cat 2....box grader #2
Not likely. Further, the 7060 is capable of turning that box blade into scrap before you can get your foot on the clutch.
   / Converting cat 1 to cat 2....box grader #4
I agree with RickB, way to small and light duty to be using behind an M7060. Save yourself the hassle and frustration and get a unit that belongs behind a tractor of that size and capabilities. ;)
   / Converting cat 1 to cat 2....box grader #5
If the width is right just slide on bushing over the cat 1 pins and be happy, you won't tear it up but probably not wide enough
   / Converting cat 1 to cat 2....box grader #6
If the QH is Cat II and the BB is Cat I do you really think the width will be “right”?
   / Converting cat 1 to cat 2....box grader #7
A couple of my Cat II implements are narrower than my rear tire width. Doesn't bother the operation, one bit, in my opinion. However, and a BIG, however - unless you are exceedingly careful - Rick B's post #2 WILL happen. Do yourself a favor and get a CatII box blade. You are NOT saving money getting a CatI implement.
   / Converting cat 1 to cat 2....box grader #8
I have an Cat 1 box blade that came with my old L4630. I bushed for use with my M6040 and have had no issues with it.
Of course, I mostly use it for snow removal which is pretty light use.
The minimal amount of earth moving I do won't ever damage it.
   / Converting cat 1 to cat 2....box grader #9
The Cat II quick hitch is the real show stopper here. Of course if the OP has torches and a welder anything is possible.
   / Converting cat 1 to cat 2....box grader #10
Inode, it appears you already own the box blade. Yes, a higher HP tractor could cause it to bend, however, if you watch what you're doing and go slow you can easily determine what will damage it before it happens. Spend $10 and buy a couple of bushing for the 3pt pins and one for the top link and see how it does. CountyLine Category 2 to 1 Lift Arm Bushing at Tractor Supply Co.
INOP Four Wheeler (A57453)
INOP Four Wheeler...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
New/Unused Spirit Electric Bicycle (A57453)
New/Unused Spirit...
Bobcat T590 (A53317)
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
