Brushhog / Mower What size can i use
   / Brushhog / Mower What size can i use #1
TheGreyRider
Central Pennsylvania
Kubota 2920
I have a few questions about brush hog mowers, or rough cut mowers hopefully someone out there can answer me some questions....
First is a brush hog the same as a rough cut, or rotary mower?
I have a kubota 2620 what size could i get?
What do i need to cut high fields and bushes and so on?
Where is a good place to purchase one? Are the TSC ones OK?
   / Brushhog / Mower What size can i use #2
1) First is a brush hog the same as a rough cut, or rotary mower?
2) I have a kubota 2620 what size could i get?
3) What do i need to cut high fields and bushes and so on?
4) Where is a good place to purchase one? Are the TSC ones OK?
1) Yes
2) The standard answer is generally 5 PTO HP per foot of cutter width; so a 5' rotary cutter would require 25 PTO HP (I don't know what yours has)
3) A rotary cutter should do the trick
4) There are many good places. TSC's are OK, but not generally the toughest. The toughest ones are generally Land Pride, Woods, Bush Hog, & a few others. It seems pretty much that you get what you pay for. You can get a cheaper cutter at TSC, but it will be a lesser cutter; And you will pay more, sometimes a lot more, for one of those brands I mentioned.
Good luck.
   / Brushhog / Mower What size can i use #3
Pretty much what beppington said, we only buy Land Pride and Woods after having used the cheaper brands. I also prefer slip clutch over shear pin.
Some people swear by flail mowers, but I have no personal experience; lots of threads on them and worth consideration.
   / Brushhog / Mower What size can i use #4
you should be able to run a 5' er,,,,but would do better with a 4',,,,,,,weight will be an issue, the 5' er will make steering more difficult without a front counter balance,,,,,,,Hogs are heavy and long so the weight is pushed back
   / Brushhog / Mower What size can i use #5
I have the 2920 and run a 5' sorry,,,,yours is 19 or 20 HP in the back,,,mine is 21-22,,,,,if your an occasional user TSC will work,,,,I got mine for $450 off craigslist,,,,,,actually I've bought almost all my implements used
   / Brushhog / Mower What size can i use #6
Besides brands previously mentioned by Beppington and Triple R,I would also look at Hawkline(previously the International not IH ).I'd get a 5'-er,and run from Queen Krutter(just there standard b-hogs). :D
Boone
   / Brushhog / Mower What size can i use #7
Don't forget to factor in the "kind" of mowing you will be doing, and how often.
By "kind" I mean the surface- rocks, anthills, gopher holes, bogs- and the green stuff -(what bullbreaker in FL mows vs TripleR, in MO) growing on it.
Are you maintaining 20 acres of pasture, cutting it every 6 weeks, or is it 3 acres you cut twice a year, "just fer purty"?
A pickup truck can haul a ton of driveway gravel 10 miles, once year, but don't go into the paving business with it!:D
   / Brushhog / Mower What size can i use #9
I use a Woods 54" cutter behind my B2620. I have turf tires and am just a little too wide to cover my tracks with a 48" cutter. My use is maintaining several acres of grasses-a 60" would probably do for me.
Will
   / Brushhog / Mower What size can i use #10
Good point, but I use this consideration in deciding "light", "medium" or "heavy duty" within a brand rather than the brand or quality.
Another consideration is how much and how often.
Now my brother on the other hand buys "no name" mowers from a discount place and replaces them every few years when the decks rusts through and he has put a couple of new gear boxes on. He mostly mows a few acres of grass no more than four or five times a year where I mow brush, saplings 3"-4", tires, motorcycle ramps, T posts, ammo boxes and assorted objects someone has neglected to pick up as well as the occasional stump or mound of crushed rock. I mow quite a bit of land about every two weeks or so.
He is also a lot better at fixing stuff than I.
Mine works for me and his works for him.
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
Toro (A56857)
Toro (A56857)
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
19008 (A56859)
19008 (A56859)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
*Selling at Royal Auction Zephyrhills, FL Location* 9, gooseneck hitch, (A59230)
*Selling at Royal...
