Using an offset flail mower to mow grass
   / Using an offset flail mower to mow grass #31
I think mowing in general is very much like snow plowing... A whole lot of variables that affect the outcome.
I find that the higher my flail is set, the worse the cut gets. 3" results in a finish mower cut in normal to slightly high turf grass. If I'm running the flail elevated over my stream bank with tall vegetation, the cut quality is much less consistent.
   / Using an offset flail mower to mow grass #32
I raised mine all the way up when I was getting the barbed wire out. I dont care too much about cut quality, but higher means I have to cut more often. It has 3 settings. I think I'll use the middle one next.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
