Best Way To Remove This Tree
/ Best Way To Remove This Tree #42
Question for those of you with experience taking trees down with a hoe: What size hoe and tree combo are you talking about?
I know the big excavators are the tools of choice for tree clearing in many (most) situations but I had never thought a <35-40lb CUT TLB set up was appropriate. I've been in the cut then dig camp but am intrigued by this new option.
I have a Kioti CK20 KB2365TLB. TLB weight is arount 3500lbs and BH Dipperstick force is about 1750lbs. Full extension is a bit under 9feet so I could probably reach 10ft up a tree. Would you try to tackle a tree similar in size to the one discussed in this post?
/ Best Way To Remove This Tree #43
I have a New Holland 555E backhoe. It's a full sized machine with 80 hp. There is no tree that is too big for me to take down with it. My biggest are over three feet thick at the trunk and heavier than I'd care to think about.
My neighbor has a guy who does jobs for him who has a pretty new Cat 315L trackhoe. He has enough reach with the trachoe that they rarely dig out around the roots. He just drives up to most trees, puts the bucket up high and pushes them over. It's a whole different world when you bring out the big machines.
I realize that my backhoe doesn't compare to a CUT, but this isn't a very large tree. If it was two feet thick through the trunk,then I'd tell him not to learn how to take out a tree with a CUT. This tree looks to be a good size that is well within his machines capabilities.
Earlier somebody mentioned learning on a different tree. If he has other trees of this size, or smaller out in the open, than I'd agree. Get some experience first if you can.
As for cutting it up high and leaving some up for leverage to dig out. Why? Its just as dangerous to cut a tree down up high as it is down low. That danger is the same either way. Digging the stump out with 4 to 6 feet of trunk in the air will give some mechanical advantage to taking out the stump, but if the tree is whole, than it provides all the weight needed to take out the stump all at once.
There is no advantage to cutting down the tree with a chainsaw if you are going to take out the stump. If you are a logger, than cutting with a chainsaw is faster, but getting that stump out becomes a big job.
One thing to be careful off is small trees. The have been the most dangerous. The trunk on sapplings and trees that are just a few inches thick are still very flexible. If you do anything wrong, they will wip arond and come right into the cab. I've had more busted knuckles from two inch thick pines than any construction job I've been on. Even down, they wip around and sanke there way into the cab, or parts of the tractor until they find a weak point, then break it off. They have also caused me more damage to my dozer than any other thing I've done with it. Be very careful when working around sapplings!!!!
Good luck,
Eddie
/ Best Way To Remove This Tree #44
EddieWalker said:
There seems to be two camps here. Those who like chainsaws and those who like backhoes. I've done both and the chainsaw way scares me.
I've heard all sorts of stories of injury or damage from a tree that's cut down with a chainsaw. The best and most experienced people with a chainsaw will all have stories of close calls, injuries or of those who died from cutting down a tree this way.
I'm sure there are the same stories of those who take out a tree with a backhoe, but as of yet, I haven't heard a single one. It would take dozens and dozens of stories to just equal all the ones I've heard about cutting down trees with a chainsaw.
I would ask those who recomend using the chainsaw to take down the tree as the better way, Have you ever taken out a tree with a backhoe, or seen it done?
Eddie ... I for one, have seen first hand someone attempt to push a tree over with a backhoe. The main trunk on the tree was either rotten, took a lightning strike or was just structurally weak. The hoe pushed the bottom 50% right over, but the top 50% landed on the bonnet of the tractor. There were minor injuries to the operator from splintering. He could have easily sustained worse. He got very lucky methinks. There is/was no way to predict this was going to be the case. Common sense must prevail. Smaller trees? No problem. Trees 30% taller than your hoe can reach? I think you're asking for a do-over.
That being said ... I'll take the chainsaw with a mindful of safety practices with me everytime. Everyone has to know their limits or risk paying exacting prices.
/ Best Way To Remove This Tree #45
Doug,
When you say that it landed on the "bonnet" I'm assuming you mean the part of the tractor that covers the engine? I must not understand you, because that would mean that the person you speak of was pushing the tree with his Front End Loader (FEL) and not the hoe stick on the back of the tractor.
I've also had this happen to me. Dead and rotten trees are about as dangerous as there is. When it happened to me the first time, I was on my my backhoe and did exactly that. I eased up to it with the bucket up high. My plan was to push it over real easy with the FEL. It snaped almost as soon as I touched it and the bottom half fell over like I wanted it to, but the top half came straight down like a spear towards the earth. It hit one of my loader arms and shot off to the side. I wasn't hurt, nor was the tractor damaged, but it sure scared me real good!!
The second time it happened, I was on the dozer. I figured it was too dangerous to do with the backhoe, so the dozer would be better. I went in low and slow and got the blad down to the roots. I pushed and lifted the blade at the same time. the results were almost identical. The tree started to go over just like I wanted, but the top part of it broke off and came down on top of me. This time it hit the tracks on one side with the rest of it landing on the ROPS. Branches broke off all over and several hit me. Fortunately they were very dry and not very heavy.
Two strikes was enough to learn that lessson. Right now I have two trees that are like this that need to come down. I had three, but one fell over in a storm. I'm gonna wait for those other two to fall over also.
There is no way that I'd try to take them out with a chainsaw. To me, it seems even more dangerous this way. I hope you are not recomending to take out dead and rotten standing trees with a chainsaw?? :confused:
My advice to use the backhoe was directed at the tree posted in this thread. Not towards any other trees.
Thanks for letting me clarify that,
Eddie
/ Best Way To Remove This Tree #46
toolaholic said:
Renze, FOUL .There are tulips in Holland! We're talking TREES Man !
Did i just p*ss in your cornflakes or something ???
My neighboor worked 30 years this way, trimming trees around electricity poles.
JasonL said:
I agree completely with Eddie on this one. I have taken down larger trees than that with my smaller tractor and BH. Since stump removal is required in this instance why waste the leverage the tree gives in helping to remove it? Also, I think you have more control over the tree at ALL times using his method. There is nothing worse than having a tree cut off at the bottom, but standing nearly vertical stuck in nearby trees. As with any job, think twice before acting and be safe! Jason
Jason,
Your tractor is very similar to mine. That gives me hope that I can tackle this tree. Thanks for the input.
Obed
EddieWalker said:
Obed,
You have the ultimate tree remover. Your backhoe.
I've taken out hundreds and hundreds of trees with it and consider one your size just a ten minute job. Of couse, the first time is always the toughest.
Eddie,
Thanks for the detailed instructions. I also looked at your post about creating your property entrance where you showed pictures of knocking over that huge pine tree with your backhoe. I tried my luck on a small tree yesterday following your instructions. Your method worked really well. I'll post pictures of my work. I have one more tree that is a little bigger to practice on before I tackle the tree that is the topic of this post.
Obed
/ Best Way To Remove This Tree #49
I once saw a guy push a silo over using a large dozer... guess where it fell? Yep... right on the dozer.
mark
dirtworksequip said:
Obed, since you don't have any experience start small and work your way up to the tree in question. I'm sure there are other smaller trees that you will need to take out on your road and property. Taking out some of the smaller trees first will give you some experience and confidence in how the whole process works.
dirtworksequip,
I took your advice and removed a smaller tree yesterday with the backhoe. I'm glad I did because I learned alot.
Obed
/ Best Way To Remove This Tree #51
Eddie, I know of one kind of dead rotten tree that is safe enough to use a chainsaw on...Osage orange/Bodark...I cut one down several years ago, it didn't have any branches on it to speak of...only difference between it and a live one was the lack of sap getting all over the saw.
I have gotten lots of great suggestions from the helpful people here. I'm planning on using the backhoe method that EddieWalker suggested to remove the tree. Here's a picture of the tree (from Eddie's "Creating an Entrance" thread) that Eddie knocked over with his backhoe. Eddie's tree. If Eddie's backhoe can knock this thing over, then my backhoe should be able to knock over the tree in my road.
While several people suggested the chainsaw route, I really want to play with my backhoe and see what it will do.
Obed
For some practice on taking down a tree, I chose small tree on the side of my road that is preventing me from creating a proper ditch. This tree was about 30 feet high but not very big around. It has a double trunk. I placed a glove in front of the tree for a perspective on size. If you look down the road in the background on the right side you can see the bigger tree that is the main subject of this post.
Here are some pictures of digging the trench on the side of the tree to which the tree will fall.
Here's the first trench completed. I dug as close to the root ball as I could. The roots on this little tree weren't too big so I was able to dig very close to the trunk.
I repositioned the backhoe to dig the trench on the other side of the tree. Although this tree is small, the roots were still tough enough that I had to be careful or I would drag my tractor toward the tree by taking too agressive of bites.
Here are pictures of the two completed trenches. It is important to note that I dig not dig entirely around the tree. Using Eddie's method as I understand it leaves roots in the ground on either side of the tree. These roots act as hinges when you push the tree over. I was amazed at the control with which the tree fell using the remaining roots acting as guides.
Here is the tractor positioned before pushing the tree over with the backhoe.
Here's the backhoe pushing on the tree. It takes a little experimenting to find the sweet spot that is just the right place to push.
Once I had started pushing on the tree I realized that I was pushing it parallel to the road. I wanted the tree to fall in the road, not beside it. Thus I decided to stop pushing and reposition the tractor a little to get a slightly different angle. However, as soon as I removed the force of the bucket on the tree, the tree fell right over beside the road instead of into the road.
Firestone 14.9 x 24 Tire, Unused (A66408)
Firestone 14.9 x...
John Deere 4955 Tractor (A66285)
John Deere 4955...
2022 EZ-GO ELITE...
Bush Hog 114 3Pt Mower (A66408)
Bush Hog 114 3Pt...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
