Best grapple for brush?
   / Best grapple for brush? #31
😇 Just another point to consider: sometimes it's not how big of thing you can pick up that matters the most, but how small of stick can be grabbed without getting off the tractor. May just be me and how I work, but I've found that not having to get off the tractor to pick up every single stick that may have fallen while moving piles can be worthwhile, as sometimes it's easier to to just use the tractor to pick up a few small sticks like this and bunch them together during final clean up. ...though having a grapple that where top and bottom tines touch helps with that (as does having the patience to learn how to use it to pick up small items quickly/efficiently). ...can also be nice to not tear up a lawn when doing it too :oops:
For reference/perspective the grapple in the picture is a 66" version of one of these: Single Lid Wicked Root Grapple Lightweight Strong Large opening ...so the non-laminated tines are 3/8" thick 😁😇
Would very much love to get to the point of being able to pick up a raw egg with an excavator (or a grapple on a tractor) without breaking it - as doing something like that would seem to require a fair amount of skill :oops:(y) (which should be able to translate to more useful skills like safely operating close to high-dollar structures/items that can't be moved). :cool:
I have the Landpride SCG1072, which resembles the second photo (grapple on tractor). I use it for all kinds of brush and tree cleanup, and while I don't know if I'd truly be happer with the grapple of the left Steinsammler (?) grapple, I've often though a grapple with longer bottom tines would make me happier. Closer and longer bottom tines might drop less material between point of pickup and the brush pile destination.
That said, I'm not unhappy with my grapple and I'm still learning various techniques. One thing I could probably do better with mine (like your right hand photo) do an equal sided drop-from-above claw-like grab on the brush. But mostly I prefer to slide the tines along the ground to get the bottom material, and I would guess the Steinsammler is better at that . My landpride bottom tines are barely tines. For example, you can't really put anything on them (to carry) even with the grapple open and tilted, stuff just slides off because they're very curved. So what isn't secured by closing the grapple is lost. There are times I wouldn't mind being able to carry my chainsaw in the grapple, but no such luck.
Carrying things w the grapple is a concern i had, like a chainsaw or gas.
i was assuming with the claw style that maybe i could close it and put the things in that way?
   / Best grapple for brush? #33
I have a lot of brush piles and down trees I’ll want to move. I can get two styles of grapples I’m wondering which one y’all would recommend.
Here is a photo of an example brush pile and the two styles of grapple.
You want one that will clamp your arm up in it. You don't want the two individual top clamps, those are awfully terrible. The rake bottom with two clamps is the worst. Get a full clam type grapple with full top and bottom clamp. We have two tracked skid steers and a 4x4 tractor that has grapples. The grapple that has two top clamps, well, when the others are busted they'll use it. It's always in good shape because out of seven operators, nobody uses. We go clean up after hurricanes. The ones that have a solid bucket bottom and have bolt in sides kinda work better, but if ize only gonna get one, I'd go full grapple.
   / Best grapple for brush? #34
My opinion... Get the one where the two jaws close separately. I mean they open together and close together but if brush is thicker on one side, that jaw will stop and the second one can continue down to grab the lower brush. It looks like the black one you show does not clamp down independently.. You'll end up dropping a lot of brush if the grapple can't hold it across the width of the grapple. Wow the guy who posted above me feel just the opposite of me. I tend to slide under the piles so long lower tines that are close together for less droppage ( as well as loading tools on) with independent closing on top jaws just works.
   / Best grapple for brush? #35
I also have a Land Pride SGC1072. I've never used the type in your first pic, but I've been very happy with the 1072.
I have several acres that are heavily forested, so I primarily use it for picking up brush and logs, and brother, it can pick up a giant pile of brush! It works great with the logs also. I keep my tractor set up for logging with a skidding winch on the back and the grapple on the front. I don't think I've had my regular bucket on for more than a day or two since I bought the tractor 3-4 years ago. I've also used mine to load/unload items onto a trailer or into my pick-up bed using a chain and hanging it off the lower tines.
You mentioned carrying stuff in the grapple... I've carried split wood in it open and tilted back with no issues. I don't think I would try to carry a chainsaw in there. Even closed it would likely bounce around somewhat unless you were driving on a smooth, paved road. With most saws having lots of plastic these days, I wouldn't want to risk breaking anything.
There is a learning curve with it as you get used to how it handles and what positions work best. You'll eventually develop techniques for whatever job you're using it for.
   / Best grapple for brush? #36
I didn't want to overload the FEL with a lot of extra weight in steel.
I find "The Thumb" to be more than adequate to grapple brush and logs, as well as rocks, and adds little weight to the front end. Can pick up huge loads of brush from tree tops, as well as anchor logs to the forks for carrying and for holding while bucking off firewood lengths.
   / Best grapple for brush? #37
That is a great setup for exactly what you describe; makes a man want TWO grapples... o_O
   / Best grapple for brush? #38
...and that's how it starts.
Get one grapple, and then see the benefits of a different style and the next thing you know you've got two grapples, and then collection just keeps growing......o_O
(trust me I know as I've already got this grapple addiction thing going with a single lid L-bottom, and a post-puller/stump-bucket style ...and desires for a few other types too ...those pallet fork style are mighty tempting, as are some of the various forestry/log grapples like the by-passing tongs, and the single lid with two tine bottom)😇
   / Best grapple for brush? #39
It's bad enough carrying things in a bucket, because you forget something is in the bucket and can destroy it. And while you can see what's in the grapple, one accidental push of the grapple "close" function for a fraction of a second and you may destroy whatever you are carrying.
That said, I have once or twice opened my grapple a bit, to put something in it without it falling out, and used bungee cords to keep it from moving about. Hack upon hack upon hack because tractors stink at carrying the little things :-/ I have also bungeed things to my rear blade arm assembly (like a mattock) for field work. Bungee cords for the win?
   / Best grapple for brush? #40
This is what I want to do! With a set of forks from either mytractortools.com or AI2. With one of their quick attaches.
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
